 rumble at the rock 5
Go to page : Previous  1, 2, 3  Next
jeeves_m_d
People Skills : 4006
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:26 pm
Well i would cody but we needed to make a lot of modifications. And our two main frame pieces have to be remade i can supply u with a cheesy edrawing pics and stuff from b4 last rumble.
People Skills : 4143
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:28 pm
okay.. This eggbeater doesn't really look like SnS, but the original drawing on the white board at school resembled it almost exactly! Turns out that it's the same weight as the drum is now.. We'll need to lighten it a bit. but here's a screenshot!
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:31 pm
how big is the SnS eggbeater? and how much does IT weigh? mine weighs over 6 right now.. it's a fatty..
jeeves_m_d
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:33 pm
thats intimidating lolcano is 4 lbs with a 7'' effective diameter. HOw about fluffy and SnS?
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:34 pm
it's 7" diameter as well.. but thick.. how thick is yours?
oh.. mines 1.25" thick most of the way.. maybe that's overkill.. lol
People Skills : 6033
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:37 pm
I think like 3.75 and 3.5 pounds give or take
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:38 pm
if you have the weight to do it why not lol
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:39 pm
really?! it's small!
I do have the weight.. but we wanted to try some other things.. like shallow wedges in front and such..
jeeves_m_d
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:40 pm
lol dont worry about being over kill man, ours is 1.5'' thick the whole way around. we KNOW that its over board but last year in the same grudge match that killed our axi executer bent our beater flat pretty beater into a curved pice of poo bcuz we were to thin near the shaft
our is just plain stell though we need to find a place that can heat treat.
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:42 pm
I was considering doing the staggered teeth like you did.. and still might. how thick are the sides? you said they were too thin.. how thick are they now? also, how wide is it? ours is 7"
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:44 pm
i think as long as your over .5" you will be fine
jeeves_m_d
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 10:46 pm
ours is milled out of a block of 1.5''the whole way
and ya the that half inch rule we dint know about bcuz we used half innch. and near and the hole for the shart left like an 1/8' or less of material in that area so it bent at that point
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:03 pm
okay.. cool.
I redesigned it.. and now it REALLY looks like a SnS on Steroids.. it's 4.2 pounds, but the same dimensions otherwise.. what do you think?
jeeves_m_d
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:18 pm
prettty, wat motor is that using?
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:24 pm
Lehner inrunner brushless.
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:26 pm
doesnt SnS beater look completly bad booty tho haha
jeeves_m_d
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:27 pm
how are they compared to axi's
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:30 pm
more expensive! lol Much more powerful, and the Axi's are outrunners, as compared to this which is an inrunner. We're getting something around 3.75 HP out of ours, after all we're running it with the worlds largest lipo pack, 6cell 5000mAh, and a 180Amp Castle controller! it's exciting
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:31 pm
well first off there twice the price lol, other then that there practicily amazing!
People Skills : 4568
INSANE.
The Motors: http://www.finedesignrc.com/motorslehner.asp
Their Specs: http://www.finedesignrc.com/lehnerspecs.htm
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:32 pm
Castles dont like our bots Sad we have like almost $1000 in electronics sitting on a shelf at school
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:33 pm
ya, we have the 10 turn 1950.
PostSubject: Re: rumble at the rock 5   Mon May 04, 2009 11:34 pm
funny about your misfortune with castle.. we've been pretty fortunate so far..
PostSubject: Re: rumble at the rock 5   Tue May 05, 2009 10:09 pm
ours is a Phoenix 180.
Concerning the competition, there isn't any. There will NOT be a June competition labeled Rumble @ the Rock. Fail.
Page 2 of 3Go to page : Previous  1, 2, 3  Next
» My Autobiography; The Ghost of Rock & Roll
» You guys rock!!!!!
» Rock Crawler 2.2 Tires
» Rock Crawling obstacle course suggestions for Bt Panjang Event on 25 Sep 11
» NASCARs at Richmond/Rock you like a hurricane 400
Battlebots :: Competitions :: Florida BotsIQ-
