| LOLCANO 3 or 4 who knows wat # we are up to now | |
+15Stephen Ryan McKinney SamM Josh Raichel SenaiERI Don Doerfler Koolaid64 Frisco rdubard rjw Jeff L Dan Curhan Cody Will Bales jeeves_m_d 19 posters |
People Skills : 6339 Registration date : 2009-03-14 Age : 32 Location : Sarasota, FL
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Sun Jul 04, 2010 12:07 pm | |
| magmotors are really powerful, and it's hard to beat one in terms of start-up torque (seeing as brushless motors usually don't have the same amounts of startup torque that brushed motors do...) but they're not like outrunners where you can bolt to the can. The wires are going to spin with the back of the motor when you hold the shaft fixed, and that's the biggest problem I see. They just don't make slip-rings with a high enough current capacity to spin at that speed. And if you did a fluid coupling... I can't imagine that being robust enough to handle the shock of battle.
All in all, I give it a thumbs up for ridiculawesomeness, but a thumbs down for feasability. | |
People Skills : 6023 Registration date : 2009-04-21 Age : 30 Location : Sudbury, MA
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Tue Jul 27, 2010 1:59 pm | |
| ok magmotor idea being scrapped, while being bored in india i cadded up another idea lolcano will now be a full body drum still trying decide on a drive system but this one seems alot more durable than than the magmotor one. il upload pix wen im back in the states | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Tue Jul 27, 2010 3:35 pm | |
| - jeeves_m_d wrote:
- ok magmotor idea being scrapped, while being bored in india i cadded up another idea lolcano will now be a full body drum still trying decide on a drive system but this one seems alot more durable than than the magmotor one. il upload pix wen im back in the states
You might consider jumping on the brushless melty bandwagon..... Could be a fairly simple build | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Thu Aug 05, 2010 3:47 pm | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Fri Aug 06, 2010 12:00 pm | |
| I think this might have promise. . .if gyro doesn't get the best of you.
I would consider putting some sort of armor around all the stuff inside the beater, just in case it stops spinning for some reason. | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Fri Aug 06, 2010 1:20 pm | |
| ya i was planning on putting in some large od steel tubing in there i just havent gotten around to it yet | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Sun Aug 08, 2010 12:09 am | |
| I'm so lost. Is that a shuffler? | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Sun Aug 08, 2010 9:15 am | |
| Um no its wheeled i just dont have the wheels in that picture. but essentially there is a wheel in each corner of those square sides powered by a larger wheel in the center | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Thu Sep 02, 2010 9:22 pm | |
| Machining has begun... So far the billet has been cut and the hole patterns were marked for the acrylic mounting members inside the beater. THat should be done by wednesday. I have an axi 4130 that i need to swap the factory shaft for a longer one, but i cant seem to get the set screws loose, I'm sort of stuck here because all my allen wrenches are just bending, does any one have any tips on getting stuborn screws out? I still need to make the following: -Weapon Pulleys -wheelguards -wheels hubs Here is another render(I got bored) | |
SamM big contributor
People Skills : 5356 Registration date : 2009-12-22
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Thu Sep 02, 2010 10:48 pm | |
| Wouldn't you be much better off with Polycarbonate or Aluminum for the motor mounts? Acrylic does not like impacts at all. | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Thu Sep 02, 2010 11:03 pm | |
| Probably... but i had the sheet just lying around my house
also it is the impact resistant type of acrylics or atleast thats what it said on the label/i was originally planning on having them lasercut but my friend who was going to do that for me backed out, so i figured just use what i have and if it breaks i will just switch it out for the polycarb | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Fri Sep 03, 2010 2:11 am | |
| why four wheels instead of three in a triangle? | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Fri Sep 03, 2010 8:41 am | |
| um, first off squares are so much easier to machine
second The triangles stick out much farther in front of the beater. So it would be a nightmare trying to get a hit
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Fri Sep 03, 2010 11:27 am | |
| hate to break it to you but its gonna be a nightmare getting a hit like that, itll be a lucky shot on a wierd angle should a corner make its way into your beater | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Fri Sep 03, 2010 11:47 am | |
| I know but its less of a nightmare than the triangles. Plus this just a body to test the concept of everything in the beater, if it functions properly i will put the beater assembly into a modified version of the older body, I just didn't want to spend the money machining a nicer body for a weapon/drive system that may not work. | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Wed Sep 15, 2010 8:27 am | |
| acrylic mounts are done wheel hubs done aximods still in progress DONE!!!! still need to machine pulleys and make wheel guards and stand offfs | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Wed Sep 15, 2010 8:25 pm | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Wed Sep 15, 2010 10:39 pm | |
| extended shaft axi more pics in the morn | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Wed Sep 15, 2010 10:51 pm | |
| Cool !! | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Sat Sep 18, 2010 10:46 pm | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Sun Sep 19, 2010 1:00 am | |
| hmm wonder how it will drive | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Sun Sep 19, 2010 9:16 am | |
| ya... i still need to get the wheels but i didn't want to order them till everything else was done. which will not be till i get the weapon pulley and wheel guards machined | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Tue Sep 21, 2010 4:36 pm | |
| weapon pulleys machined, but they are driven with friction wheels now instead of belts | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now Tue Sep 28, 2010 6:08 pm | |
| Everything is done other than wheel guards, which will take a few weeks while we get the new mill setup
but tommorow will be spent wiring and assembling and filing/sanding anything that don't fit | |
| Subject: Re: LOLCANO 3 or 4 who knows wat # we are up to now | |
