 What the heck Weapon should i choose?!
Go to page : Previous  1, 2, 3, 4
People Skills : 5721
PostSubject: Re: What the heck Weapon should i choose?!   Tue Nov 03, 2009 10:42 pm
Cody Harris wrote:
i have 3/8" stuck in my head for a shaft with needle bearings
I bent a 3/8 hard shaft in Sting.....lol....I don't think it would do too well in a 15 pounder
People Skills : 3998
PostSubject: Re: What the heck Weapon should i choose?!   Tue Nov 03, 2009 10:43 pm
That sounds more like something I would do!
I love the design btw! should work!
People Skills : 5888
PostSubject: Re: What the heck Weapon should i choose?!   Tue Nov 03, 2009 11:02 pm
Man i'm to old to remember numbers anymore
Im probably wrong im sure but what the hey that was two years ago
I oddly have 3/8" on after and 1/2" on still in my head, maybe 1/2" on after and 5/8" on still, hmmmmm i could ask alex but i bugged him alot about hockey bots earlier lol
o yeah Mr. Frisco if your looking for an extra hockey bot on your team Alex is going to see if he can use original shockwave minus a weapon as a hockey bot.
Josh Raichel
People Skills : 3564
PostSubject: Re: What the heck Weapon should i choose?!   Wed Nov 04, 2009 1:02 am
Working on the armour now. Its gonna consist of a underlayer of 3/8'' aluminum with a nice thick piece of UHMW capped over it. Just a mockup of the sides, the rear will get a layer of UHMW aswell.
I may do another version with a floating wedge i used for Redemption.
Since i got all this put on its close to its final size/footprint.
Its about 9.5 inches from front of the front plates to the rear plate, and from the outsides of the the UHMW to each other about 14 inches
People Skills : 3476
PostSubject: Re: What the heck Weapon should i choose?!   Wed Nov 04, 2009 9:29 am
Is the original shockwave 12 #'s
PostSubject: Re: What the heck Weapon should i choose?!   Wed Nov 04, 2009 9:45 am
Drum design looks good....
Almost the same as Rocko and our first robot.....
I will point this out..... There is a lot of chatter and not good bite with this design.......
I dont know why but we have never really had a good bite with anything under 4" and a flat blade........
The offset teeth will help as to put more time between hits but you should rake angle the back of the S7 and Cove them on the impact side.
We have went as far out as 1.5 inches from the drum and had good results with the S7 not bending or breaking... at 1 inch plus we have bent the 6061 drum where the slides go to mount the S7.
All drums were using the same set-up for attachment as yours. We actually used a regular .5 inch ID .75 OD .25 W bearing on both sides of the drum that was pressed into a 2.5 diameter piece of 6061 then used 4 bolts to attach the drum to the 6061. Attached the timing pulley to the end with 6 bolts just outside of the bearing piece that houses the 6061.
See if you can find any pics of XLR8ED or Rocko on Bots IQ
PostSubject: Re: What the heck Weapon should i choose?!   Wed Nov 04, 2009 9:58 am
It was a little over 13 pounds when we competed with it two years ago
A123s -weapon/weapon motor it should be right there on weight
Josh Raichel
PostSubject: Re: What the heck Weapon should i choose?!   Wed Nov 04, 2009 10:10 pm
I found a Solidworks model of Redemption so i put Boreas and Redemption side to side.
Made me chuckle quite a bit. Very Happy
Solidworks butchered the Redemption model but hes mostly there....mostly..
I still have many many refinements to do the Boreas that will make it a bit more compact, (notice the larg space between the weapon and frame.
PostSubject: Re: What the heck Weapon should i choose?!   Wed Nov 04, 2009 10:38 pm
Question:
Is that the biggest beater ever on a 15 lbs bot???? Razz
Josh Raichel
PostSubject: Re: What the heck Weapon should i choose?!   Wed Nov 04, 2009 10:48 pm
rjw wrote:
Question:
It was ShamWOW! close, especially the thicker one made for Nationals.
5 pounds of S7 glory.
PostSubject: Re: What the heck Weapon should i choose?!   Thu Nov 05, 2009 10:44 pm
its a pretty freakin big beater lol it was wide too
PostSubject: Re: What the heck Weapon should i choose?!   Thu Nov 05, 2009 10:51 pm
Josh Raichel wrote:
rjw wrote:
Question:
It only weighs 2 pounds more than Sting......waaaaaa Razz
and it's probably thrice the size LxW or more...hahaha
If you put the bot on its side, and turn on the beater, does the bot spin instead of the beater???
PostSubject: Re: What the heck Weapon should i choose?!   Thu Nov 05, 2009 10:53 pm
It didnt even have a terrible gyro, being so wide helped ALOT
Josh Raichel
PostSubject: Re: What the heck Weapon should i choose?!   Thu Nov 05, 2009 11:22 pm
Oh it had gyro.... Our 1" Cube Magnet eliminated that at Nationals. But at 8,000rpm it had minimal gyro..
Tell Alex and the rest of the Plum gang to keep a bot handy for a grudge match at CalU or Century III.... I may resurrect Redemption. Muahahahaha.
Wink
And no rj, it does not. Very Happy It did get stuck on its side at Nationals, and when i layed on the throttle the bot turned a bit, then eventually flipped itself back over.
PostSubject: Re: What the heck Weapon should i choose?!   Thu Nov 05, 2009 11:27 pm
Wink
If you wanted it to, just make a longer shaft sticking out the side and glue a small suction cup to the end of it....hahaha..... bounce
It could sub as a full body thwackbot when on its side!!!!
PostSubject: Re: What the heck Weapon should i choose?!   Thu Nov 05, 2009 11:35 pm
the magnets you were playing with at Century three lol
maybe aftershock, its on a shelf now too just like both shockwaves
what happens to your bots?
Josh Raichel
PostSubject: Re: What the heck Weapon should i choose?!   Thu Nov 05, 2009 11:56 pm
Those magnets i was playing with were hard drive magnets.
We got a bunch of magnets donated to us. We used the 1'' for Redemption at Century 3 and the .75'' we used i think the first day at Nationals. If we had those at Century or Ohio it would have been great!
I still have two of the .75'' ones. They are fun as hell. Very Happy
As for our bots, get massacred for the next bot or at least for extra electronics. Bosshawg currently is in pieces and Redemption is a shell with no electronics. Groundhawg is the same and Warthawg is gutted aswell.
I wanna take Redemption but he is school property... Sad
I will get a beater at least.. Razz
PostSubject: Re: What the heck Weapon should i choose?!   Fri Nov 06, 2009 12:32 am
Our school has nothing to do with our bots team so its just like the "clubs" property i guess
Page 4 of 4Go to page : Previous  1, 2, 3, 4
» Choose my Warband
» Wiggles Random Weapon Generator (RMXP)
» new champion: zac the secret weapon
» Torch - weapon or equipment
» Which Pill Do You Choose?
