- Frisco wrote:
- What do you mean by Derate? Eliminating from Weapon and running one from drive esc??
What price for 2 or 3 XL's not XX?
We have used 12-45's but 2 gave out on use last year... Our Scorpion XL never went bad in 2 years!
Would the XXL's cover enough amperage for the 15's??????
if you look at the specs on the bb's and scorpions, you might notice that as you up the voltage, that the bec gets de-rated...in other words it can only supply a very small amount of bec power...not enough for the br6000 (reliably) syptoms were intermittent loss of signal
We had bec problems when going to 5 cel lipos, while none with 5 cel LiIons. we had to use a stand alone bec on ttatt while using an xxl for drive and a bb 12-45 for weapon....Sting'em gets its bec from the mamba monster without problems
We only use the XXL's in our 15's....stall even on the 540 motors is somewhat high...we've been using bb 550's, aftermarket 550's and total insanity 550's....without problems with xxl's
we'd rather burn out a $5 or $10 motor than a $100 xll...does this make sense...mind you , we run fast, push hard and still have only smoked 1 or 2 bb 550's with xxl's mind you.
pm me and I'll see what I can do on the pricing
also, I've mentioned this elsewhere, but with a dx6i radio and a reversing weapon, between the xl and some mixing, 1 swich can be used to reverse EVERYTHING on an invertable bot.....
Makes it a lot easier on the drivers......baaaaaah....rookies all of them...
Thanks
Richard
