| Dean Removable link | |
People Skills : 5765 Registration date : 2009-04-30 Age : 33 Location : Bradenville, PA
| Subject: Re: Dean Removable link Tue Jul 13, 2010 7:24 pm | |
| Single deans female. Loop of wire. Use good solder, shrink it, and electrical tape it. Then you can use the loop to pull the deans out.
ZIP TIE IT OR MAKE ANOTHER KIND OF SUPPORT. it will come out from a hard hit.
Design a metal piece to lock between them and not allow them to come apart.
Other wise its simple, light and cheap. I recommend it. | |
| Subject: Re: Dean Removable link Tue Jul 13, 2010 8:39 pm | |
| or you go to rjw for a switch like his like I already have I got dibs!!! | |
| Subject: Re: Dean Removable link Tue Jul 13, 2010 10:35 pm | |
| - Josh Raichel wrote:
- Single deans female. .
Uh, don't you mean single deans MALE? Cuz if the removed part is female, then the male is two exposed conductors just waiting to accidentally short and turn your robot on. (Also why the batteries always have females on them--a disconnected battery is difficult to short!) ps-don't ask me how I know this. . . | |
donsun
People Skills : 5506 Registration date : 2009-04-30 Age : 33 Location : Ridgewood, NJ / Atlanta, GA
| Subject: Re: Dean Removable link Wed Jul 14, 2010 12:16 am | |
| our team used the removable deans power switch for all our bots including antweights (micro deans). just wire the bot so that it turns on if u simply plug in the battery, then jus cut one of the power wires and add a female dean. then with the male dean, solder the outputs together and that should be your switch. pretty simple and reliable | |
donsun
| Subject: Re: Dean Removable link Wed Jul 14, 2010 12:22 am | |
| in the antweights with micro deans, we just made a bridge with solder and covered with electrical tape. for hobbies we used a short piece of 12 gauge noodle wire to connect the leads and jus covered with electrical tape. i'll try to find a pic if i have, but should be pretty simple to understand. | |
| Subject: Re: Dean Removable link Wed Jul 14, 2010 12:32 am | |
| Dean and noodle wire bridge. Thats all you need Alex. | |
| Subject: Re: Dean Removable link Wed Jul 14, 2010 12:59 am | |
| Whatever noodle wire is. 12 gauge? i forgot. USE THICK STUFF. | |
donsun
| Subject: Re: Dean Removable link Wed Jul 14, 2010 1:30 am | |
| it doesn't have to be noodle wire, i jus use it cuz it's the most flexible which only requires me to use a short length of wire. if you have a local hobby store, you should be able to find it there. jus do whatevr u need to connect the two leads together ;P | |
| Subject: Re: Dean Removable link Wed Jul 14, 2010 6:31 pm | |
| Subject: Re: Dean Removable link | |
