 Battle hardeded 42mm gearboxes with 775 motors
People Skills : 5837
PostSubject: Battle hardeded 42mm gearboxes with 775 motors   Fri Jan 29, 2010 10:31 pm
As many of you probably already know, Robot Power is importing a 42mm gearbox, similar to what Banebots used to sell.
taking it a step or 2 further, I cooperated with Chris from Robot Power, to beef these up and make them battle hardened.
Chris posted a few pictures of them, so here they are
we discussed a few other minor mods and hopefully he can get the manufacturer (Will's friend Jackie Chan) to make this an OEM product
If interested, contact Chris from robot power.
btw: the 2 samples that I saw ran very smooth, had all steel gears and ring, etc. Threaded mounting hole locations were a bit wishy washy, but nothing that can't be dealt with.
Josh Raichel
People Skills : 3680
PostSubject: Re: Battle hardeded 42mm gearboxes with 775 motors   Fri Jan 29, 2010 11:05 pm
I'll take free samples to test.
PostSubject: Re: Battle hardeded 42mm gearboxes with 775 motors   Fri Jan 29, 2010 11:32 pm
Ya...me too.....I received them, modded them and then shipped them back...so we'z in da same canoe
I suppose that a pair of these in a pushy bot (12 ro 15 lbs) with lots of rubber on the ground could do some serious pushy damage!!!
more of a 30/60/120 spider pig type gbox tho...too heavy for a 12 or 15 unless..... alien
then again. you could always call Chris and BEG!!!!!... affraid
RC TTwins
People Skills : 3016
Registration date : 2010-04-20
PostSubject: Re: Battle hardeded 42mm gearboxes with 775 motors   Fri Sep 17, 2010 9:50 pm
Duel Mamba Monster Max's in a pushy????
PostSubject: Re: Battle hardeded 42mm gearboxes with 775 motors   Sat Sep 18, 2010 1:01 am
only for possible bragging rights....you can get away with much smaller motors and not make a difference....as long as you have anough power to light up the tires, you won;t get any more to the ground. On a 12/15 lbs. bot, with typical 16 -20:1 gbox, and 2-3" wheels, much smaller brushless motors will do the job just fine.
Use the extra weight elsewhere.....weapon/armor/whatever
jmo
» MFA Como drillls - motors,gearboxes and belt drives.
» Helmuth's Strongholds Battle for Arnhem ruined house 2
» 2 Mordheim battle reports
» Wi-Fi battle anyone?
