| Ripto-Beetleweight | |
+13Alex P. HASD Bots SenaiERI rjw Stephen Lambo1 Will Bales rdubard Dan Curhan Don Doerfler Cody jeeves_m_d Frisco Koolaid64 17 posters |
| Subject: Re: Ripto-Beetleweight Thu May 05, 2011 12:12 am | |
| nice, sounds like you should have some pretty nice equipment to play with | |
People Skills : 4982 Registration date : 2011-03-30 Location : south west pa
| Subject: Re: Ripto-Beetleweight Thu May 05, 2011 2:12 pm | |
| yep my mill isn't full size (about 2:3) size but still can do a descent amount of stuff on it- I did a lot of work for my bots team= which equals lots of long nights in the basement, any way back to your disk, did you offset center, and then use a rotary table to rotate and cut at a slow speed | |
| Subject: Re: Ripto-Beetleweight Thu May 05, 2011 2:43 pm | |
| for the disc, first i made a design in my design program and played with the on hole size and location until i got the center of gravity in line with the spinning axis. after i did that i cut off a 3/8 wide piece from my 4.5" cro-moly round stock. i then popped that in a lathe and faced both sides down until it was 5/16" wide, plus i now have a finished surface to work with, then i pilot drilled then plowed a 1" bit through the center giving me my arbor hole. now for the funer parts, i made a fixture that fit inside the arbor hole of the disc and held it on center of the rotary table. i then cut exactly one half of the disc to a 3.25 dia. then i drilled my bolt circle and balancing hole. i then cut off the excess material on each side of the tooth with a band saw. i then cut up to each side of the tooth using the radius of the end mill to cut the radius on the tooth. here is the on paper design, i takes a second to figure it out but everything you need to make it is there | |
| Subject: Re: Ripto-Beetleweight Thu May 05, 2011 3:03 pm | |
| impressive | |
| Subject: Re: Ripto-Beetleweight Thu May 05, 2011 8:55 pm | |
| Man, you are a genius--I would ONLY consider doing this with CNC, but you did it with much simpler tools. Great work! | |
| Subject: Re: Ripto-Beetleweight Thu May 05, 2011 10:21 pm | |
| thanks, it was fairly simple to. at least compared to the three tooth one, i only had to re-set it once and it popped right back into place thanks to the fixture. the one i made from ti was a pain, i spent like 20 mins resetting it to cut each tooth. | |
| Subject: Re: Ripto-Beetleweight Fri May 06, 2011 4:27 am | |
| Could it have been possible without the rotary table? Not that it matters, but I was just thinking that before we got the CNC, I had thought a rotary table would be a real help with the manual mill. I guess there's no reason to buy one now. . . | |
| Subject: Re: Ripto-Beetleweight Fri May 06, 2011 11:38 pm | |
| not really sure how you would cut the radius without it, im sure you could change the design to straight cuts and have half a octagon on one side of the disc | |
| Subject: Re: Ripto-Beetleweight Sat May 07, 2011 5:39 pm | |
| the new Ripto is coming along nicely | |
| Subject: Re: Ripto-Beetleweight Sat May 07, 2011 11:54 pm | |
| got a tiny bit more done | |
| Subject: Re: Ripto-Beetleweight Sun May 08, 2011 1:26 pm | |
| the frame is now pretty much finished up. here is a comparison shot next to the old version the current weight with weapon, drives, and battery is at 33oz witch is pretty sweet considering the weapon is 13oz of that | |
| Subject: Re: Ripto-Beetleweight Sun May 08, 2011 1:38 pm | |
| yup, a little HF mini mill and i also have a 9x20 lathe | |
jtm94 great contributor
People Skills : 5350 Registration date : 2010-04-23 Age : 29 Location : Clairton, PA
| Subject: Re: Ripto-Beetleweight Sun May 08, 2011 5:24 pm | |
People Skills : 4891 Registration date : 2011-04-10 Age : 29 Location : Blaine Minnesota
| Subject: Re: Ripto-Beetleweight Sun May 08, 2011 6:05 pm | |
| lol, size comparisons to the computer as well XD | |
People Skills : 5090 Registration date : 2011-02-05 Age : 33 Location : towson md
| Subject: Re: Ripto-Beetleweight Wed Jun 22, 2011 4:03 pm | |
| Im excited to fight this! | |
| Subject: Re: Ripto-Beetleweight Wed Jun 22, 2011 11:32 pm | |
| im excited to finish it. should be another day or two if i work on it hard core
| Subject: Re: Ripto-Beetleweight Sun Jun 26, 2011 8:07 am | |
| that looks menacing can i drive? | |
| Subject: Re: Ripto-Beetleweight Sun Jun 26, 2011 3:23 pm | |
| arn't you working on your own bot? | |
| Subject: Re: Ripto-Beetleweight Sun Jun 26, 2011 3:39 pm | |
| yes... | |
People Skills : 5608 Registration date : 2009-12-24 Age : 29 Location : Plum,Pa
| Subject: Re: Ripto-Beetleweight Sun Jun 26, 2011 4:25 pm | |
| Subject: Re: Ripto-Beetleweight Sun Jun 26, 2011 9:08 pm | |
| perfect world math says ~16000rpm real world, who cares, its hits poo hard
https://www.facebook.com/video/video.php?v=10150344371772067
| Subject: Re: Ripto-Beetleweight Sun Jun 26, 2011 9:34 pm | |
| weapon safety, osha approved | |
| Subject: Re: Ripto-Beetleweight Mon Jun 27, 2011 9:04 am | |
| Now I need some wheel guards, any idea of the ke it makes? | |
| Subject: Re: Ripto-Beetleweight Mon Jun 27, 2011 11:52 am | |
| haven't bothered to calculate, disc is 4.5" dia, ~12oz, at (with friction/drag/ and what not) ~14000rpm | |
| Subject: Re: Ripto-Beetleweight | |
