 Mounting the end of the weapon motor shaft.
Alex Udanis
People Skills: 2637
Registration date: 2009-03-29
PostSubject: Mounting the end of the weapon motor shaft.   Sat Feb 27, 2010 9:07 am
Who here using a bearing at the end of their weapon motor shaft? Here at plum we have always, but i was looking at some hobbyweights and i didn't see a single one we any additional support other than the the motor's own bearings. Rick what do you use? rjw? Thanks for your help guys. -Alex
http://www.alexudanis.com
People Skills: 3504
Registration date: 2009-03-31
PostSubject: Re: Mounting the end of the weapon motor shaft.   Sat Feb 27, 2010 10:34 am
We used to use an outboard support when we used timing pulleys
Since we switched to smooth pulley over smooth drum, we no longer use the outboard support.
I think that without it, you might be fine, depending on your motor and what steps you take to make sure that it stays together.
I also noticed that all use timing belts and no outboard support...I think that a heavy drum is a better candidate for this than a beater tho...the drum carries more energy and can dampen a lot of the shock
jmo
btw: which bot(s) are you thinking of removing the support and with which motors?
also, if you are usng an outrunner with a 5mm shaft (for axample) check shaft hardness...it's possible that ifit's soft, you sould exchange it for a 5mm hardened dowel pin...like I do in little Sting
People Skills: 3707
Registration date: 2009-03-16
PostSubject: Re: Mounting the end of the weapon motor shaft.   Sat Feb 27, 2010 6:52 pm
Im guessing its for the new four wheel drive drum, its supper close on weight
there using inrunners with supports on the rear so the cant twist and such
i think you may be able to get away with out
People Skills: 1368
Registration date: 2009-11-01
PostSubject: Re: Mounting the end of the weapon motor shaft.   Sun Feb 28, 2010 7:20 pm
We have always supported it with a bearing on the end....
I just think it is safer????????
People Skills: 1890
Registration date: 2009-03-15
PostSubject: Re: Mounting the end of the weapon motor shaft.   Mon Mar 01, 2010 10:58 pm
meh... on moving-around drive, I haven't really worried about it a lot. however, new fluffy's gonna have it. we put a bearing on the other side of the motor pulley to the drum, and it made all the difference!
» modul E5143 Kawalan motor/motor control
» Crafting Weapon Wind Level 55
» Mounting the end of the weapon motor shaft.
» weapon motor rpms
» Spinning drum on a 15 pound Battle Bot.
