 What material is better for a spinner weapon?
Goto page : 1, 2, 3, 4  Next
Andy
People Skills: 793
Registration date: 2010-04-16
PostSubject: What material is better for a spinner weapon?   Wed Apr 21, 2010 9:17 pm
What material is best for a beater or drum?
beater- titanium or tool steel for axle?
- titanium or tools steel for the actual beater?
Drum- I'm assuming aluminum for the drum, but what alloy?
- titanium or tool steel for the teeth?
jeeves_m_d
People Skills: 1736
Registration date: 2009-04-21
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 9:38 pm
Beater's typically have 2 options the first is cutting it out of a thick solid plate of steel and heat treat it. the other to have very thick aluminum sides with steel teeth bolted together in a manner that the bolt are not under enough stress to shear. Titanium is generally not used because i believe that it is to soft to do any damage this is the same reason that the aluminum isn't used as teeth. The reason that it isn't used to make the side arm like the aluminum is that it is much harder to work with so it would be hard to get a good bolt pattern in there cheaply or accurately. SO NO MATTER WHAT MAKE SURE THE PART THAT HITS THE OTHER ROBOT IS STEEL preferably hardened tool. I have built many beaters and i prefer the cut out steel method rather than the aluminum steel bolt method. As for drum you are right about the aluminum body because that is what popular. But RJW has had a lot of luck with his solid S7 drums and that may be another option for you. But the TEETH ON ANY WEAPON BEATER OR DRUM MUST BE STEEL the other material just can't take it. I have seen titanium drums deform on impact... i have met any one silly enough to do aluminum teeth yet. I haven't seen a titanium beater because a chunk of material thick enough to machine out of would god awful expensive.
Josh Raichel
People Skills: 1456
Registration date: 2009-04-30
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 9:52 pm
Titanium works fine as weapon teeth. Trust me. It is softer than tool steel, but its springy and withstands high impact very well. Its not too bad as a beater either providing you get the good grade treated stuff. Titanium is HELL for weapons. But for its cost, S7 Tool Steel is more economical and effective. I personally have a love affair with Titanium.
Absolute BEST Tool steel is the Aermet stuff. Aermet 100 has CRAZY impact toughness. I want some soooo bad but it costs 3x more than S7 i believe.
A 3/4 inch hollow Titanium shaft is great to support your weapon. Aluminum is a good drum material, but inserting steel teeth gives you the chance of them shearing out of the soft Aluminum.
And please hit "enter" more often so i can read that without my eyes hurting. 1 giant paragraph is not forum reader friendly.
Andy
People Skills: 793
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 10:05 pm
Anyone who was a century III mall botsiq please correct me f I'm wrong, but I believe fayetee had a full Ti beater and it tore through our 1/16 Ti armor.
Hypotheticaly if I could aquire such a nice chunk of Ti do you guys have any recommendarions as to how I would properly heat treat it and where I could get my metal heat treated?
Also, do you think solid 1/2 Ti axle would be as good as 3/4 hollow?
P.S. I also really like titanium. But of course i've never had to machine it other than drill holes or countersink it lol
Josh Raichel
People Skills: 1456
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 10:12 pm
Fayette AVTS did have a full Ti Beater. And it did GOOD.
As for heat treating it depends on what kind of Titanium you get to begin with. I believe our stuff has been Solution Annealed and its quite awesome in this state.
1/2 inch solid is NOT better than a Hollow 1/2 or 3/4.
jeeves_m_d
People Skills: 1736
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 10:15 pm
sorry josh.... is the beater on redemption Ti? I was going off of what i saw on my friends Ti drum teeth. But if you have had positive experiences with it I am mistaken.
Josh Raichel
People Skills: 1456
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 10:17 pm
Redemption's is S7. but our shafts are hollow 3/4 Titanium That is slightly harder than its outer titanium plates/armour.
People Skills: 3504
Registration date: 2009-03-31
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 10:31 pm
For a great drum on a budget...look at Paul V's ntertainment.
Steel tube with steel teeth welded on....you'll make weight and be able to withstand just about anything.
here's a pic ...staggered tooth drum
.I saw this fight live and the video soundtrack deosn't do it justice. The sound of steel to steel was just amazing. Also remember that in MANY cases , hits to the drum body will occur.
so an aluminum drum in a bloodbath like this IS NOT going to cut the mustard...jmo
here's a video of solid steel drum vs solid steel vertical blades
http://www.youtube.com/user/botman64#p/u/54/HSwkE9SB0nA
Do it right and 'Avoid the Pain'
I believe that Paul's bot is running a solid 1/2" Ti shaft on oilites, but look at the 1" wide bushing/shaft supports on each end.
On a side note, wheremost will take the win when an opponent is stuck, Paul doesn't leave Zandor stuck on the wall (in the beginning) or stuck on its face (later on)....He loses in the end, when he had at least 2 chances of winning by count out.....It's a code of honor type thing, I believe.
People Skills: 1294
Registration date: 2009-12-24
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 10:48 pm
If you are using a drum you should prabably use 6061 or 2024 aluminum and S7 or Titanium teeth
http://www.youtube.com/user/DoerflerRobotics?feature=mhum
People Skills: 3707
Registration date: 2009-03-16
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 11:20 pm
alot of this depends on size and weight you are shooting for
People Skills: 2314
Registration date: 2009-03-14
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 11:28 pm
Couldn't help myself Laughing. But yes, the overall dimensions and mass of your weapon will determine the absolute best material to use.
People Skills: 3504
PostSubject: Re: What material is better for a spinner weapon?   Wed Apr 21, 2010 11:40 pm
Correct me if I'm wrong, but I have never seen a 15 pound ALU drum bot take a beating like in that video and not tap or get trashed.
Certainly not any Plum or Bloomsberg bot in 2008 vs Hummdinger.
But, I could be wrong.... Wink
People Skills: 3707
PostSubject: Re: What material is better for a spinner weapon?   Thu Apr 22, 2010 8:59 am
our drums held up fine against humdinger though
we taped cause the original designed sucked at driving inverted and our we lost drive to a side and were flipped
People Skills: 3504
PostSubject: Re: What material is better for a spinner weapon?   Thu Apr 22, 2010 9:12 am
I'm trying to be informative not arguamentative, but didn't 1 of the shockbots have a big gash in it...I believe that you stated..compliments of Hummdinger...? On occasion, we've seen alu drums or complete bots trashed in a matter of seconds....example: Sting's hammerhead after 1 hit vs Jamo's cake , etc.
I guess that my point in showing Paul's drum, is that possibly more would have access to someone who can weld rather than lathes, cnc, etc.
Seems the least complicated/expensive to cut 2 or 3 pieces of square tool steel, a tube, a pair of endcaps and have it all welded up. Perhaps even with the typical alu endcaps with notches.
Plan B: machined alu tube, accurately cut for tool steel inserts, possibly nut bars, etc.
Plan C: cnc'd tube or from solid....ala Jamo, mlec.....time consuming, 4th axis, etc.
vs steel fbs, ss style horizontals, etc. I put my money on steel.
exception would be K2/Witch Doctor style bots with blades an inch or so larger in diameter...which protects the alu hub.
With weapons getting bigger and stronger and the fact that sometimes they stop spinning, I don't see a really big future fo alu as typical drum material....jmo
From the pic below, how many more of those gashes can an alu drum take , before it needs to be retired?
People Skills: 2028
PostSubject: Re: What material is better for a spinner weapon?   Thu Apr 22, 2010 12:15 pm
rjw, i have to agree with you - I'm not at all a big fan of aluminum weapons. Copperhead's steel drum made it a virtually indestructible surface for any kind of weapon - keep it pointed at the opponent, and even if it's not spinning, they have to deal with the consequences of hitting it. It's kind of like MLEC's titanium bricks - opponents will beat themselves up on the solidity of our bots, but we'll sustain little damage.
If your weapon is aluminum, it become vulnerable the second it stops working, so even if you have indestructo-armor on the other three sides, when the drum stops spinning, it becomes the bot's weak point. You're only protected on three sides instead of all four.
Page 1 of 4Goto page : 1, 2, 3, 4  Next
» Crafting Weapon Wind Level 55
» What material is better for a spinner weapon?
» weapon spec repository - dimensions, material, weight, speed, inertia, energy...
» songle-blade antweight weapon
» Antweight full body spinner first antweight :)
Battlebots :: Bots :: Design-
