| | So today i took a broken Eggbeater up to 25,000rpm.. | |
| | Author | Message |
People Skills : 5800 Registration date : 2009-04-30 Age : 33 Location : Bradenville, PA
| Subject: So today i took a broken Eggbeater up to 25,000rpm.. Thu Apr 22, 2010 5:36 pm | |
| And other than the ENORMOUS amp draw. Redemptions beater was very balanced... Seems like that crack improved the beater. Gave it a stress relief point. It got us through a entire day of grudge matches, and a big Rumble full of big hits. Watching it, and hearing it. It would be the LAST thing i would want to fight. Wish i could get it up to that speed and not melt the bot... So do the math. 5.125 diameter S7 beater. Hardened to 54RC. Weighs about 4.7 pounds. Spinning at 25,000rpm.. 400mph tip speed... KE = SHAMWOOOW! Think it will hold up with that crack in it if i am spinning at a tame 8,000rpm? With lots of hits? Heres the crack.... | |
| | | Jeff L Minister of Silly Walks
People Skills : 6582 Registration date : 2009-03-14 Age : 35 Location : Miami, FL / Atlanta, GA
| Subject: Re: So today i took a broken Eggbeater up to 25,000rpm.. Thu Apr 22, 2010 5:44 pm | |
| Hmm... I don't see any reason why it shouldn't continue working fine for a little while, but I can definitely tell you you're going to have a ton of wear from torsion where the outer section of the beater meets that center joint as well as where it meets the outside edge of the material (leading up to either another crack, or the steel bending out of shape). I'm going with "replace as soon as possible." | |
| | | Don Doerfler super contributor
People Skills : 5644 Registration date : 2009-12-24 Age : 30 Location : Plum,Pa
| Subject: Re: So today i took a broken Eggbeater up to 25,000rpm.. Thu Apr 22, 2010 5:48 pm | |
| did it crack all the way through | |
| Subject: Re: So today i took a broken Eggbeater up to 25,000rpm.. Thu Apr 22, 2010 5:53 pm | |
| Yep you can see in the pics that it did..
I know it needs replaced, but I want to try to have Redemption win nationals with a cracked weapon. For lulz. Curious as to what others think it will do... | |
| Subject: Re: So today i took a broken Eggbeater up to 25,000rpm.. Thu Apr 22, 2010 5:58 pm | |
| You could have it welded thats what we did with Still'n Shocks weapons | |
| | | Cody 2000+ club
People Skills : 7819 Registration date : 2009-03-16
| Subject: Re: So today i took a broken Eggbeater up to 25,000rpm.. Thu Apr 22, 2010 6:11 pm | |
| if you weld it i'd only go for a tack on either side
youll make it more brittle in that spot then it already is
Either way its only a matter of time till something breaks
Running it the way it is might work out the way it is but who knows what itll do to the rest of the bot | |
| | | Sponsored content
| Subject: Re: So today i took a broken Eggbeater up to 25,000rpm.. | |
Similar topics | |
