IQ 2011 Miami 5 3 4
 IQ 2011 Miami
Goto page : 1, 2, 3 ... 9, 10, 11  Next
RemoteContact
People Skills: 1038
Registration date: 2009-10-15
PostSubject: IQ 2011 Miami   Sun Apr 25, 2010 9:18 pm
Edit- Thanks Dan.
At IQ 2010 Nola announced IQ 2011 to be in February 2011 in Miami...Plenty of lead time!!!
Got plans? CAD? Comments? Anything?
Post'em here.
Personally I'll be back probably as an FIU team to avoid the whole Pro vs College thing. Bringing back an upgraded Witch Doctor for sure and maybe something new. Come on fellow college kids.... lets get some more 120's active!
People Skills: 2314
Registration date: 2009-03-14
PostSubject: Re: IQ 2011 Miami   Sun Apr 25, 2010 10:08 pm
We'll probably be able to attend - Sum of all Fears is still slowly creeping toward completion, and we should start testing at the beginning of Fall semester. We might even be able to get non-NiCad batteries!
RemoteContact
People Skills: 1038
PostSubject: Re: IQ 2011 Miami   Sun Apr 25, 2010 10:11 pm
If you wanna roll A123 lemme know. I'll hook you up.
People Skills: 3504
Registration date: 2009-03-31
PostSubject: Re: IQ 2011 Miami   Sun Apr 25, 2010 10:35 pm
can you elaborate on the 'whole pro vs college thing'
thanks
RemoteContact
People Skills: 1038
PostSubject: Re: IQ 2011 Miami   Sun Apr 25, 2010 10:50 pm
Busted Nut Robotics is Mike, Paul and me. I'm the only one in college so we registered as Pro. At the beginning of the event is was unclear who exactly we were fighting but it got resolved and turned out fine. Competing as FIU would just make things less complicated.
People Skills: 3504
PostSubject: Re: IQ 2011 Miami   Sun Apr 25, 2010 11:09 pm
i asked, cause out kids may actually get a 120 together for next year....
one problem is tip speed....in hs it's limited to 300 fps, college is 400 and pro is 500....if they max out at 300 and have to face college and pros, which would probably happen, especially if the numbers are low, then we would like to know that we can turn up the juice, if facing non hs teams
RemoteContact
People Skills: 1038
PostSubject: Re: IQ 2011 Miami   Sun Apr 25, 2010 11:45 pm
Worried about tip speed on the 120lber that's in that 3dpdf? I see those shorties are being geared up. Must be running 36v too. Mags may be "82%" efficient but that's peak. Efficiency at lower rpms (where you'll spend more time then most because of gearing up instead of down) is much less, meaning even more heat which means demagnetized magnets (has happened to me with a C40 mag which has even higher temp magnets), overheated brushes, melted insulation on internal motor leads, or cut armature windings. I've personally had all of those happen to me. You would need a current limit somewhere (esc or battery) but that would make spinup painfully slow to reach those high rpms. All I'm saying is plan on adjustable ratios.... or a retrodirect 2spd gearbox....
People Skills: 3504
PostSubject: Re: IQ 2011 Miami   Mon Apr 26, 2010 12:02 am
Actually, at this point we have some of the long and short mags, an ampflow esc, etc. so they are designing according to what they have at the moment.
I personally have little experience with the mags, and if we had the budget, we'd be looking into brushless alternatives and keep the mags as backups for the drivetrain.
drum will probably weigh around 25 pounds and will certainly be running on bearings. any suggestions? I've only looked at some of the bigger neu motors so far....but I think that with their current design, that they could probably fit almost anything in there...
RemoteContact
People Skills: 1038
PostSubject: Re: IQ 2011 Miami   Mon Apr 26, 2010 12:21 am
http://www.astroflight.com/index.php?main_page=product_info&cPath=9&products_id=123&zenid=jgibk8bvvafvmvb0hljsrbfoij7cmlec
http://www.plettenberg-motoren.com/UK/Motoren/aussen/Predator/Motor.htm
http://www.hobby-lobby.com/axi_gold_5330_20_double_outrunner_motor_3048_prd1.htm?pSearchQueryId=601002
People Skills: 3504
PostSubject: Re: IQ 2011 Miami   Mon Apr 26, 2010 12:31 am
don\'t think that any of those would have the r\'s that we want ...in keeping with the current philosophy of.....too fast, too loud, all show and no go....
we were thinkin something more along the line of a pair from this page
http://www.neumotors.com/Site/2200_series.html
People Skills: 3707
Registration date: 2009-03-16
PostSubject: Re: IQ 2011 Miami   Mon Apr 26, 2010 12:39 am
still not the specs, i just want someone to use it
http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=5139&Product_Name=Turnigy_80-100-A_180Kv_Brushless_Outrunner_(eq:_70-55)
the link wont work for me :/
People Skills: 3504
PostSubject: Re: IQ 2011 Miami   Mon Apr 26, 2010 12:53 am
I'll say one thing for the hype on neu/castle motors.
They aren't lying when they talk about heat/efficiency. after playing with some align, axi, feigao, scorpion and a few other motors, the neu's definitely run a lot cooler. we use a laser temp gauge to monitor under various loads and the difference has in general been somewhat drastic.
I've heard a lot of good things about the astros, nad have spoken with the head honcho over here on a few occasions....but haven't tried any of their motors personally.
I would just like to hear an offset tooth or single tooth drum in a 120 at over 20 or 30k...just for giggles.....
RemoteContact
People Skills: 1038
PostSubject: Re: IQ 2011 Miami   Mon Apr 26, 2010 2:26 am
The cool part about astroflight is that Bob will sell you a motor with a custom (read hot) wind for not much more. He'll also do dual shafts, powdercoating, 6 phase leads instead of three for delta/wye switching, etc.
People Skills: 1569
Registration date: 2009-06-10
PostSubject: Re: IQ 2011 Miami   Mon Apr 26, 2010 5:22 am
:Ummm, the guy who started this thread used that motor--in his winning robot, Witch Doctor.
It was exactly as awesome as you might guess.
People Skills: 3707
PostSubject: Re: IQ 2011 Miami   Mon Apr 26, 2010 11:15 am
wellllll i havent seen any decent inside pictures
IQ 2011 Miami
Page 1 of 11Goto page : 1, 2, 3 ... 9, 10, 11  Next
» If CSI: Miami met the Nekketsu Kunio Series...
» Majalah PC ( UPDATE MEI 2011 )
»  Wisata Bugil Paling Sensasional di 2011
» Inscrieri FIFA 2011 - Management Mode [Sezonul 1]
» 9/17/2011 - Opening of the Dev Blog. [+out of memory error fixed]
Battlebots :: Competitions :: Florida BotsIQ-
