 Ring Spinners Anyone?
Goto page : 1, 2, 3  Next
jeeves_m_d
People Skills: 1736
Registration date: 2009-04-21
PostSubject: Ring Spinners Anyone?   Mon Apr 26, 2010 7:29 pm
I've had this idea in my head for a long while now, I'm finally cadding it up. its a bit more of a private bot than an LS bot. The idea is a ring spinner that uses the friction system that has been working so well in various FBS bots. I'm actually essentially taking my FBS design and making it invertible, the only difference is the shell and mounting hardware. I might actually be a bit lighter this way. I cant really describe it but I will have cads tonight or tommorow
jeeves_m_d
People Skills: 1736
PostSubject: Re: Ring Spinners Anyone?   Mon Apr 26, 2010 9:33 pm
PRELIMINARY DRAWINGS LEMME KNOW WHAT YOU THINK
INTERNAL LAYOUT:
sHELL:
BASICALLY 2WD BOT WHEEL IN THAT CENTER CUT OUT
WEAPON IS COMPRISED OF 1/4'' THICK WALL 12'' OD STEEL TUBE WITH ALUMINUM LIPS BOLTED INTO TOP AND BOTTOM, THE TOP HAS TWO AXI'S WITH WHEELS PRESSED AGAINST IT WHILE THE BOTTOM HAS TO IDLER WHEELS PRESSED AGAINST IT TO MAINTAIN TENSION AND STABILITY. THE LITTLE CIRCLES ARE NOT POWERED THEY ARE JUST TO KEEP THE SHELL IN PLACE. SORRY FOR THE CAPS
People Skills: 3504
Registration date: 2009-03-31
PostSubject: Re: Ring Spinners Anyone?   Mon Apr 26, 2010 10:43 pm
Why not go experimental and build a melty???
Carrolton in Miami started on one, but it never made it to nat's.... Sad
Not sure about bolting alu pieces to 1/4" wall steel....max size screw would be maybe 8-32's 10's would be wishful.
blade(s) ??? coming soon.....
People Skills: 3707
Registration date: 2009-03-16
PostSubject: Re: Ring Spinners Anyone?   Mon Apr 26, 2010 10:46 pm
i think aluminum lips is asking for a point of failure
jeeves_m_d
People Skills: 1736
PostSubject: Re: Ring Spinners Anyone?   Mon Apr 26, 2010 11:30 pm
i have weight for steel lips its just that i wanted to stop my self in advanced from trying to weld them on
teeth coming soon
melty... im just not that smart
People Skills: 3504
PostSubject: Re: Ring Spinners Anyone?   Mon Apr 26, 2010 11:41 pm
talk to some of the guys on the rfl....I'm sure they'd be happy to hook you up...
People Skills: 1368
Registration date: 2009-11-01
PostSubject: Re: Ring Spinners Anyone?   Tue Apr 27, 2010 11:12 am
Bearing setup is somewhat similiar to ours but we ran a 3/8 frame inside to make the bearing supports more rigid...
The Ring lip is only needed on one side (bottom) instead of both.
Is the center open?????
We went with 4 Bearings on the H Frame Ends and brought 2 - 1/2 inch pieces off the middle of the H Frame at 90 Degree to throw in 2 more supports on the longer sides of the frame...
This gave us a total of 6 1" bearings running on 3/8 5850 Precision Shafts.
A Pretty rigid setup and it will hold up against a good rum but way too intense when gyro is involved...
Hard to Drive (uncontrollable) when spinning..
Our Ring was 7/8 by 3 wide 6061..
jeeves_m_d
People Skills: 1736
PostSubject: Re: Ring Spinners Anyone?   Tue Apr 27, 2010 4:09 pm
I don't seem to understand what your saying frisco, do you have any pics i haven't been able to find any good pics of ring spinners i have only seen ransoms and ingor eater of souls so any good pics would be really appreciated
People Skills: 3504
PostSubject: Re: Ring Spinners Anyone?   Tue Apr 27, 2010 11:25 pm
I say...buy a wok and build a Ziggy
SamM
People Skills: 1016
Registration date: 2009-12-22
PostSubject: Re: Ring Spinners Anyone?   Wed Apr 28, 2010 12:06 am
I think it was Ziggo that used a wok. Whenever I hear Ziggy I think of the SHW pneumatic flipper.
People Skills: 1890
Registration date: 2009-03-15
hey! I pulled the wok trick on 15's first! and it's ziggo btw..
Hefferbot was a 14" wok from KMart spun by 2 dewalts. I loved it!
People Skills: 3504
PostSubject: Re: Ring Spinners Anyone?   Wed Apr 28, 2010 12:10 am
My bad... ziggo it was......OFS sets in.
Will...what happened to yours?
People Skills: 1890
PostSubject: Re: Ring Spinners Anyone?   Wed Apr 28, 2010 12:15 am
well.. I was a 6th grader when we first built it.. rebuilt it in 7th.. then freshman year we toyed around with it, successfully driving alex mattaway nuts!
People Skills: 2314
Registration date: 2009-03-14
PostSubject: Re: Ring Spinners Anyone?   Mon May 10, 2010 12:12 pm
Working on my MELTY-drive shell spinner freak-of-nature bot, I think I've found a way to restrain ring spinners for lightweight robots. If your shell has a T cross-section (the top of the T being the outer wall), you can avoid contact wheels entirely if you use properly restrained ball bearings (not ball bearing races, just the little metal spheres). Not sure how well this would work on larger robots, they may wear too quickly under greater stress & weight.
People Skills: 2314
PostSubject: Re: Ring Spinners Anyone?   Wed May 12, 2010 1:22 am
Decided to shelf the melty part of the project for now; I might try it as an upgrade later. However:
6" Ring OD, 6.75" with the teeth [the whole thing is 1" tall]. That might get a bit smaller (weight is a little tight at the moment, but I've got plenty of space to work with). The ring itself is aluminum with two steel teeth, and the chassis is currently UHMW. The ring is supported by thirty 0.125" ball bearings held by the chassis & interior ring geometry - I have yet to decide on the material, although steel is a likely bet (even though it'll grind the chassis & ring all to hell, I suspect it'll work fine for the expected operational life of the robot). I'm looking at a plain two-wheel drive, with a small brushless outrunner to drive the ring itself. The outrunner will be mounted on a spring-loaded arm (a rubber band may be sufficient for that purpose) and contact the interior ring geometry directly.
Page 1 of 3Goto page : 1, 2, 3  Next
» Ring Spinners Anyone?
» 2"Burrell Smokebox tube / smokebox door ring
» A Ring Of Endless Light
» Reverse Ring Micros
» [25.09.10] SNSD’s Tiffany phát hành bài hát 'Ring' cho OST bộ phim 'Haru'
Battlebots :: Bots :: Design-
