| Full-Body Drum | |
| Subject: Full-Body Drum Sun Mar 22, 2009 4:53 pm | |
| From The Idea Dump: - Quote :
- Full-Body Drum
Will spotted these a few years back, and I decided to take a bit of a closer look into them (scroll down until you see Daffodil versions 1 & 2):
http://www.happyrobots.com/retired.html
Pretty straightforward, it could be advantageous because you get to use most of your weight toward the drum & internals, as opposed to using it towards the typical chassis & armor configuration. I would actually make one change to the above design (mainly for the now-popular large-diameter drums): Instead of two large wheels, have three smaller wheels geared into the output shaft of your gearbox in a planetary configuration - all three wheels will rotate in the same direction, maybe getting you something closer to a tank drive than just a two-wheel drive. | |
That Guy samurai jesus
People Skills : 6002 Registration date : 2009-03-16 Age : 31 Location : Pinecrest, Florida
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 7:40 pm | |
| That looks really, really cool. It's like a shell spinner, but sideways. | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 8:34 pm | |
| Yeah. I'm working on rough sketch work for a 12/15 lb robot at the moment, but a 120 lber would be pretty epic. I'm thinking a one-foot diameter drum would be about standard for that scale, which would be pretty insane. | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 9:03 pm | |
| That would need some pretty big wheels if you want it to be okay if gets flipped though. | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 9:07 pm | |
| Of course. Three per side arranged in a triangle, actually (the whole tank-drive thing). Another thing I just realized was the drum in a 120 could easily use 70 pounds, possibly 80, on the drum alone (no need for armor). | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 9:39 pm | |
| How the hell would you spin an 80 lb drum with a 1 foot diameter? | |
People Skills : 6164 Registration date : 2009-03-15 Age : 31 Location : Miami, FL
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 9:48 pm | |
| Big-Ass perm motor! I've been wanting to do one for a while now! we should do it | |
People Skills : 5942 Registration date : 2009-03-16 Age : 31 Location : Miami
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 9:55 pm | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 10:54 pm | |
| Eddie and I have been working up plans for a bot just like this for a year and a half now too! we arrived at the exact same 3 wheels on a planetary gearbox idea as well... We should both build them and compete lol. | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 10:56 pm | |
| okay! ours will be 15 pounds probably.. then a 120 | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 10:58 pm | |
| last week eddie spent a few hours trying to shrink our 120 design to a 15... i have yet to master solidworks lol so i draw on paper and 2D autocad2000... | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 11:29 pm | |
| it would be crazy to make the three wheel a single assembly that you take off, where you have like a single mounting bar with a drive motor on each side and on each side of the bot you have 3 or 4 ev warriors or something, using like a sprocket friction drive to the drum
not to sure about weights but itd be sick | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 11:31 pm | |
| What I'm wondering is what a fight between a full-body spinner and a full-body drum would look like... | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 11:32 pm | |
| i see a wheel coming off the drum :-/ | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 11:33 pm | |
| I see a 120 lb full body spinner flying through the air. | |
| Subject: Re: Full-Body Drum Sun Mar 22, 2009 11:35 pm | |
| I see a good fight! | |
| Subject: Re: Full-Body Drum | |
| Full-Body Drum | |
