 Antweight Drive Motors
People Skills : 4423
PostSubject: Antweight Drive Motors   Sun May 23, 2010 9:16 pm
I'm looking around at drive motors for ants at the moment, and I'm curious if anyone's had experience using these:
http://www.robotmarketplace.com/products/IL-SAN50.html
Do they seem good enough for a two-wheel drive, or would I need something a bit beefier?
EDIT: While I'm at it, these are the ESCs I've picked out for now:
http://www.robotmarketplace.com/products/0-SCORP-MINI2.html
People Skills : 4136
PostSubject: Re: Antweight Drive Motors   Mon May 24, 2010 7:08 pm
Those gearmotors will get the job done, but they don't last. For a 2wd bot, you may want to buy 4 of them, and make them fairly easy to replace in your design. I definitely recommend using the brackets RMP sells with them (http://www.robotmarketplace.com/products/0-PL989.html) because they're contoured to clip in with the gearbox quite nicely. The difference between the white (extended) and black is that the white ones have the mounting holes for the bracket somewhere near the middle of the gearmotor assembly, while the black ones have the holes up front by the gearhead.
As far as the scorpion goes, I haven't actually used that particular one, but I've heard good things about Scorpion's reputation. Personally, if I were to design a bot NOT using Fingertech's tinyESCs (which are really tiny, but not quite as durable as some of the other ones out there), I like Sabertooths, although Richard hasn't had much luck with them... I usually use a pair of TinyESCs.
Maxons are really the way to go with antweight drive, but man, they're EXPENSIVE. And kinda hard to get a hold of too...
PostSubject: Re: Antweight Drive Motors   Fri Jun 04, 2010 11:50 pm
Side Note: I found some interesting ESCs that may work well for insect bot drives (and possibly hobbyweights) while poking around:
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9090&Product_Name=Turnigy_20A_BRUSHED_ESC
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6468&Product_Name=Turnigy_30A_BRUSHED_ESC
(I'm not going to use these on my antweight though, they're a little on the large side)
PostSubject: Re: Antweight Drive Motors   Sat Jun 05, 2010 9:57 pm
Are they reversible? I just ordered two of them cause I'm impulsive... haha
PostSubject: Re: Antweight Drive Motors   Sat Jun 05, 2010 10:06 pm
No clue Razz
PostSubject: Re: Antweight Drive Motors   Sun Jun 06, 2010 7:10 pm
Another cool Brushed ESC:
http://www.sparkfun.com/commerce/product_info.php?products_id=9668
50A continuous, PWM controlled, accepts 9-24V (fan only works with 12V though).
Jamo_G
People Skills : 3179
Registration date : 2009-07-12
PostSubject: Re: Antweight Drive Motors   Tue Aug 10, 2010 1:59 am
The hobbycity escs posted above are not reversible.
On a related note, be careful when using hobby escs for robot use. Several reasons:
1) hobby controllers have a delay going in reverse because some racing scenarios call for a reverse delay. Some delays are programmable but nearly impossible to get to 0.0 seconds. Tekin Rebels were popular because they could get very close, but never goes away. Duratrax are a no no.
2) hobby controllers have a significantly decreased reverse amperage. Most notable are boat escs which feature reverse. These typically do not suffer from the reverse delay but they are more prone to exploding because of the decreased current. ex. Mtroniks
Heed the warnings!
-Jamo
People Skills : 3713
PostSubject: Re: Antweight Drive Motors   Tue Aug 10, 2010 7:01 am
fingertech has some awesome ant motors. there the only reliable thing i found other then maxons http://www.fingertechrobotics.com/proddetail.php?prod=ft-spark16-xxx
PostSubject: Re: Antweight Drive Motors   Tue Aug 10, 2010 10:07 pm
yes, the spark motors are pretty good. They're a "replacement" for the banebots 18mm gearmotors which were of... questionable quality.
buy them from rmp so you don't have to ship from canada!
PostSubject: Re: Antweight Drive Motors   Wed Aug 11, 2010 5:29 am
16mm
PostSubject: Re: Antweight Drive Motors   Thu Aug 12, 2010 12:25 am
...that's what i meant lol
People Skills : 5888
PostSubject: Re: Antweight Drive Motors   Thu Aug 12, 2010 11:09 pm
Heed the warnings!
-Jamo
do you have any hobbyweight esc suggestions lol
» Foden Kit 21A - Drive Gears
» FANtasy DRIVE at NHMS
» Drive Through Fight Over Chicken Nuggets
» What Car Do You Drive?
