 Back to the drawling boards... because CADs to kool for skewl
4 posters
Brandon Roberts
Brandon Roberts
People Skills : 5217
Registration date : 2010-04-26
Back to the drawling boards... because CADs to kool for skewl Empty
PostSubject: Back to the drawling boards... because CADs to kool for skewl   Back to the drawling boards... because CADs to kool for skewl I_icon_minitimeMon May 24, 2010 12:48 am
well thanks to you guys we decided on the beater bar....maybe a drum next year to Cool ......thing is though, over the weekend i was testing some mock ups with wood. while its no metal of course the results really set me back, and heres the issue
wer going to use a heavy steel (most likely s7) because of its strength and stopping power. but wer dead lost in thickness to length ratios, and since wer on a very very tight budget. we cant really afford to make a weapon that with crack.
point #2 is wer using p60's and bane bot motors and side by side we need around at least 10 inch length to fit both motors in and have room for wiring.
In the end we are stumped on is where the "Golden" area is on dimensions. and as always any reply is always a HUGE help towards me and James
sorry for the rough description. CAD is still a mystery to us and even a simple design takes a long while to produce. i could throw a rough sketch up tho if need be.
People Skills : 7775
PostSubject: Re: Back to the drawling boards... because CADs to kool for skewl   Back to the drawling boards... because CADs to kool for skewl I_icon_minitimeMon May 24, 2010 1:50 am
throw up the cad or sketch...it helps...no matter what it looks like..
Is this a 2 wheeled bot?
If so, then leave 1/4 to 1/2" minimum between the P60's (back to back)
If it's a 4 wheeled bot, it's more expenisve and harder, but you could offset the Gboxes, like we do...look at pics of R2RCR or MLEC on this site to see how that works.
Easier is back to back (conventional like most others)
You need the room to get a Gbox w/motor out...so plan accordingly.
As has been said here before, at least 1/2" crossection everywhere on the beater....I prefer more.
Brandon Roberts
Brandon Roberts
PostSubject: Re: Back to the drawling boards... because CADs to kool for skewl   Back to the drawling boards... because CADs to kool for skewl I_icon_minitimeMon May 24, 2010 8:39 am
we are going to use a 2 wheel drive with o rings....simliar to what warthog did
the post concerning that idea is https://battlebots.forumotion.com/design-f2/round-urethane-belt-drive-t432.htm
il toss up atleast a sketch today
People Skills : 7822
PostSubject: Re: Back to the drawling boards... because CADs to kool for skewl   Back to the drawling boards... because CADs to kool for skewl I_icon_minitimeMon May 24, 2010 8:51 am
you can easily do a 11"x 4"x1.5" beater around 3.5lbs
keep in mind your weapon doesnt have to be the entire length of the bot, make it narrower to beef up the thickness
beaters weight are usually pretty easy, s7's density is about .283
just subtract the inside area from the outside area and multiply by the density and you'll have a pretty close weight
ps sharp corners on the inside of the beater could end up being a stress point
Brandon Roberts
Brandon Roberts
PostSubject: Re: Back to the drawling boards... because CADs to kool for skewl   Back to the drawling boards... because CADs to kool for skewl I_icon_minitimeMon May 24, 2010 10:41 am
Cody once again you are my hero
People Skills : 6377
PostSubject: Re: Back to the drawling boards... because CADs to kool for skewl   Back to the drawling boards... because CADs to kool for skewl I_icon_minitimeMon May 24, 2010 7:02 pm
cody meant volume... lol
but I'm sure you figured that out.
And 2 wheel drive with O-rings? wouldn't that still be 4WD, just with 2 motors?
» throw back
» Back for 2010-2011 Season
Battlebots :: Bots :: Design-
