 Dean Removable link
Josh Raichel
People Skills : 3563
PostSubject: Re: Dean Removable link   Tue Jul 13, 2010 7:24 pm
Single deans female. Loop of wire. Use good solder, shrink it, and electrical tape it. Then you can use the loop to pull the deans out.
ZIP TIE IT OR MAKE ANOTHER KIND OF SUPPORT. it will come out from a hard hit.
Design a metal piece to lock between them and not allow them to come apart.
Other wise its simple, light and cheap. I recommend it.
People Skills : 5887
PostSubject: Re: Dean Removable link   Tue Jul 13, 2010 8:39 pm
or you go to rjw for a switch like his like I already have Razz
I got dibs!!!
People Skills : 3705
PostSubject: Re: Dean Removable link   Tue Jul 13, 2010 10:35 pm
Josh Raichel wrote:
Single deans female. .
Uh, don't you mean single deans MALE?
Cuz if the removed part is female, then the male is two exposed conductors just waiting to accidentally short and turn your robot on. (Also why the batteries always have females on them--a disconnected battery is difficult to short!)
ps-don't ask me how I know this. . . Smile
Josh Raichel
PostSubject: Re: Dean Removable link   Tue Jul 13, 2010 11:42 pm
Caught meh... ShamWOW!. Was trying to sabatoge. >Smile
donsun
People Skills : 3287
PostSubject: Re: Dean Removable link   Wed Jul 14, 2010 12:16 am
our team used the removable deans power switch for all our bots including antweights (micro deans). just wire the bot so that it turns on if u simply plug in the battery, then jus cut one of the power wires and add a female dean. then with the male dean, solder the outputs together and that should be your switch. pretty simple and reliable
http://www.enigmarobotics.com
donsun
PostSubject: Re: Dean Removable link   Wed Jul 14, 2010 12:22 am
in the antweights with micro deans, we just made a bridge with solder and covered with electrical tape. for hobbies we used a short piece of 12 gauge noodle wire to connect the leads and jus covered with electrical tape. i'll try to find a pic if i have, but should be pretty simple to understand.
Josh Raichel
PostSubject: Re: Dean Removable link   Wed Jul 14, 2010 12:32 am
Dean and noodle wire bridge. Thats all you need Alex.
Josh Raichel
PostSubject: Re: Dean Removable link   Wed Jul 14, 2010 12:36 am
Alex Udanis wrote:
But I don't have noodle wire Sad
14gauge wire then. Just solder the freakin thing on, and insulate the tabs.
Josh Raichel
PostSubject: Re: Dean Removable link   Wed Jul 14, 2010 12:59 am
Whatever noodle wire is. 12 gauge? i forgot. USE THICK STUFF.
donsun
PostSubject: Re: Dean Removable link   Wed Jul 14, 2010 1:30 am
it doesn't have to be noodle wire, i jus use it cuz it's the most flexible which only requires me to use a short length of wire. if you have a local hobby store, you should be able to find it there. jus do whatevr u need to connect the two leads together ;P
PostSubject: Re: Dean Removable link   Wed Jul 14, 2010 6:31 pm
caugh* jagoff
Dean Removable link
» valve, expansion link and reverser adjustment
» Link Swaps
» Safari missing link neanderthalers.
» Forest of Dean Pottery - Peter Saysell
» [RULES] New Field & LINK Summon
