| Subject: Battle hardeded 42mm gearboxes with 775 motors Fri Jan 29, 2010 10:31 pm | |
| As many of you probably already know, Robot Power is importing a 42mm gearbox, similar to what Banebots used to sell. taking it a step or 2 further, I cooperated with Chris from Robot Power, to beef these up and make them battle hardened. Chris posted a few pictures of them, so here they are we discussed a few other minor mods and hopefully he can get the manufacturer (Will's friend Jackie Chan) to make this an OEM product If interested, contact Chris from robot power. btw: the 2 samples that I saw ran very smooth, had all steel gears and ring, etc. Threaded mounting hole locations were a bit wishy washy, but nothing that can't be dealt with.
People Skills : 5765 Registration date : 2009-04-30 Age : 33 Location : Bradenville, PA
| Subject: Re: Battle hardeded 42mm gearboxes with 775 motors Fri Jan 29, 2010 11:05 pm | |
| I'll take free samples to test. | |
| Subject: Re: Battle hardeded 42mm gearboxes with 775 motors Fri Jan 29, 2010 11:32 pm | |
| - Josh Raichel wrote:
- I'll take free samples to test.
Ya...me too.....I received them, modded them and then shipped them back...so we'z in da same canoe I suppose that a pair of these in a pushy bot (12 ro 15 lbs) with lots of rubber on the ground could do some serious pushy damage!!! more of a 30/60/120 spider pig type gbox tho...too heavy for a 12 or 15 unless..... then again. you could always call Chris and BEG!!!!!... | |
RC TTwins
People Skills : 5127 Registration date : 2010-04-20 Age : 31 Location : Derry
| Subject: Re: Battle hardeded 42mm gearboxes with 775 motors Fri Sep 17, 2010 9:50 pm | |
| Duel Mamba Monster Max's in a pushy???? | |
| Subject: Re: Battle hardeded 42mm gearboxes with 775 motors Sat Sep 18, 2010 1:01 am | |
| - RC TTwins wrote:
- Duel Mamba Monster Max's in a pushy????
only for possible bragging rights....you can get away with much smaller motors and not make a difference....as long as you have anough power to light up the tires, you won;t get any more to the ground. On a 12/15 lbs. bot, with typical 16 -20:1 gbox, and 2-3" wheels, much smaller brushless motors will do the job just fine. Use the extra weight elsewhere.....weapon/armor/whatever jmo | |
| Subject: Re: Battle hardeded 42mm gearboxes with 775 motors | |
