 Bending Aluminum Alloys
Ryan McKinney
People Skills : 3003
PostSubject: Bending Aluminum Alloys   Sat Sep 04, 2010 11:20 pm
I need to make a lightweight bracket for something on my antweight, and all I have to work with is 1/16" 2024 aluminum. I know 2024 isn't easy to bend (I just tried to see if it would work and the piece broke) but is there a way to make bending 1/16" 2024 at a 90 degree angle possible? Would heating it up with a butane torch do any good, or should I just spend the money on a different alloy and if so, which one?
People Skills : 5866
PostSubject: Re: Bending Aluminum Alloys   Sat Sep 04, 2010 11:44 pm
not sure about 2024, but other alloys like 7075 don't like to be bent either.
It aslo depends on the actual angle and a larger radius in the bend could help.
6061 bends easily, but again tight radius usually means fracture. If you need a tight 90, perhaps a piece of angle would be more suitable
People Skills : 4143
PostSubject: Re: Bending Aluminum Alloys   Sat Sep 11, 2010 10:00 am
heat it up. I've heated up 2024 and 7075 with a propane torch and bent it 90 degrees no problem.
PostSubject: Re: Bending Aluminum Alloys   Sat Sep 11, 2010 10:01 am
**Just be careful! As you may know, Aluminum doesn't change color when it heats up. It just turns into a puddle of molten aluminum on the floor without ever changing color like steel does.
People Skills : 3851
PostSubject: Re: Bending Aluminum Alloys   Sat Sep 11, 2010 1:54 pm
I'm with Richard on this one--buy some angle. Yeh, you may be able to heat it and bend it, but it won't be as strong. A good extruded angle stock will be simpler and stronger.
PostSubject: Re: Bending Aluminum Alloys   Sat Sep 11, 2010 2:29 pm
I'm with Bob..... Laughing
PostSubject: Re: Bending Aluminum Alloys   Sat Sep 11, 2010 10:23 pm
touché
PostSubject: Re: Bending Aluminum Alloys   Sun Sep 12, 2010 1:57 pm
i'm with touché...and not Bob? scratch
PostSubject: Re: Bending Aluminum Alloys   Sun Sep 12, 2010 8:58 pm
maybe two.
Ryan McKinney
PostSubject: Re: Bending Aluminum Alloys   Fri Oct 15, 2010 7:00 pm
I ended up using a 1/32" sheet of pure aluminum. It worked perfectly
PostSubject: Re: Bending Aluminum Alloys   Fri Oct 15, 2010 9:11 pm
Pure aluminum? Where did you find that?
Ryan McKinney
PostSubject: Re: Bending Aluminum Alloys   Fri Oct 15, 2010 9:25 pm
1100 Aluminum from Mcmaster, so technically it's only 99% aluminum. I probably could've gotten it at Alro Metals, but it was only 5 bucks and I was already ordering some stuff...
PostSubject: Re: Bending Aluminum Alloys   Fri Oct 15, 2010 9:44 pm
So things are coming together?
Pics???
» LT1 Aluminum heads
» 1996 Caprice Classic 15" Alloys with Center Caps for TRADE!!!
» Roadmaster Aluminum Wheels
» LT1 Aluminum Heads
» Iron vs Aluminum
