 New CNC Machine so excited!!!!
jeeves_m_d
People Skills : 3979
PostSubject: New CNC Machine so excited!!!!   Tue Sep 21, 2010 4:31 pm
LS ROBOTICS will be recieving a Matsuura MC 500V CNC Mill from a local machine shop looking for a tax write off. The thing is in good condition but the rs232 board needs replacing. And we can only have it if it fits through the door with out heavy modification.
question are:
Is anyone familiar with this machine?
Rough Size, because i have not seen it in person?
Is replacing a RS232 interface board Difficult/ Expensive?
People Skills : 5839
PostSubject: Re: New CNC Machine so excited!!!!   Tue Sep 21, 2010 7:51 pm
How old is it?
I assume that the video is NOT of the actual machine that you're getting?
That could be a very nice machine, if it's in decent condition.
Any tooling with it? (as in tool holders, cause they can get pricey)
jeeves_m_d
PostSubject: Re: New CNC Machine so excited!!!!   Tue Sep 21, 2010 9:42 pm
from the pictures it looks identical to the one in the video, and toolings are a maybe
People Skills : 3824
PostSubject: Re: New CNC Machine so excited!!!!   Wed Sep 22, 2010 5:00 am
wow, from the looks of it, that thing can machine some very large parts, and most importantly
AUTOMATIC TOOL CHANGES!!
Changing tools is such a time killer that we often try to figure out the best way to avoid them.
jeeves_m_d
PostSubject: Re: New CNC Machine so excited!!!!   Wed Sep 22, 2010 6:33 am
I KNOW!!!!!!!!!!
the problem is I have never used a mac hine like this.... the only cnc I personally have used is a small denford educational CNC router, so im not sure if there is a different variation of gcode, or if all g code is the same?
PostSubject: Re: New CNC Machine so excited!!!!   Wed Sep 22, 2010 9:33 am
tha gcode stuff is the least of your problems...
get the machine in the door and working...the rest will fall into place...
jeeves_m_d
PostSubject: Re: New CNC Machine so excited!!!!   Wed Oct 06, 2010 8:32 pm
Machine is in the building!!!!!
I had the freshmen spend a few hours cleaning it and it is mostly sludgefree now we just need to get it operational
jeeves_m_d
PostSubject: Re: New CNC Machine so excited!!!!   Wed Dec 08, 2010 7:40 pm
The machine has been operational for a few weeks now,we have been doing some basic machining in MDI, gotta love circular interpolation!!!
still to do, get computer interface working
and figure out how to turn on the flood coolant
crowconor
People Skills : 2898
Registration date : 2010-11-06
PostSubject: Re: New CNC Machine so excited!!!!   Wed Dec 08, 2010 8:58 pm
what language does that cnc use? with are machine there is a a command you can write in your code to turn on coolant. Also what computer software do you use?
jeeves_m_d
PostSubject: Re: New CNC Machine so excited!!!!   Wed Dec 08, 2010 9:27 pm
unknown really?
there is no computer interface right now because we got it with a fried RS232 PC board(one of the reasonn the company actually let us have it) so we don't have any software at the moment.
it uses a yasnak controller but i believe all gcode is the same but the controller requires a certain type of header. M8 should be the universal coollant code i believe but im not sure, when i say we are trying to figure out how to turn it on I meant wiring wise,
too make it fit through the small shop doors it had to be dissassembled, and we weren't too sure how to put it back together.
I've tried typing in blocks of code manually into the machine memory but i get format error alarms... but when i plug the same commmands in line by line in MDI mode it works fine which is frustrating when trying to do longer opeation that need to be repeated
crowconor
PostSubject: Re: New CNC Machine so excited!!!!   Thu Dec 09, 2010 6:00 pm
yes m8 or m08 is another, is it possible to write a code manually and run it or is that involved in the missing interface? cause writing manually is relatively easy unless your using arcs or circles
i have a chart of g and m codes i could give you, but i dont know how to upload it scratch
jeeves_m_d
PostSubject: Re: New CNC Machine so excited!!!!   Thu Dec 09, 2010 6:36 pm
ya thats what we have been doing... u put the machine in MDI(manual data/direct input) mode and type in the codes line by line. It works but its just that if i have to make the same piece 3 times i would prefer having the code saved to memory and have it run automatically.
Manual if fairly easy even for arcs and circles just use g3 and g2 codes.
Right now I am fully capable of machining manually, i can do all the complex cuts. It just when u need to machine an entire robot thats ALOT of repetitive typing
I would much rather just take my solidworks file and plug it into the mill, or atleast be able to hook it up to a post processor like mach 3 or VR milling, so i could just copy and paste the gcode i get from solidcam(solidworks addon)
If you want to just email it to me jeevesmd@gmail.com that would be cool
crowconor
PostSubject: Re: New CNC Machine so excited!!!!   Thu Dec 09, 2010 7:23 pm
ill email it to you, i use mach 3, do you need a copy? i can most likely get you one
jeeves_m_d
PostSubject: Re: New CNC Machine so excited!!!!   Thu Dec 09, 2010 8:08 pm
That would be great!!
but until we get the replacement pc board we can't connect the computer Crying or Very sad
crowconor
PostSubject: Re: New CNC Machine so excited!!!!   Thu Dec 09, 2010 9:01 pm
ill work on it, im pretty sure i can hook it up though
SenaiERI
People Skills : 3832
PostSubject: Re: New CNC Machine so excited!!!!   Thu Dec 16, 2010 3:53 am
NICE DUDE! CONGRATS!!!
Yeah I love my Haas Mini Mill. She's my baby and i don't care what the school says, when i graduate, i'm taking here with me.
» used sizzix machine (orignal red type)
» help machine quilting
» Mr. Planemaker's Flying Machine
» X-Cut Impress machine
» Next best thing to a time machine...if you're from Boston anyway
Battlebots :: Team Update Pages :: Lincoln-Sudbury High School-
