Share
 120 lb. Drum Bot
Go to page : Previous  1, 2
People Skills : 6276
120 lb. Drum Bot - Page 2 Empty
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeMon Oct 18, 2010 9:35 am
ive actually looked at the turnigy motor you posted and would love to put it in a minibike someday
just to see what happens Smile
People Skills : 6123
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeMon Oct 18, 2010 10:28 am
there are some big azz escs floating around, or use 2 smaller motors or DIY
People Skills : 4605
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeMon Oct 18, 2010 3:05 pm
there are definitely some BIG current escs for cheap from china. That outrunner is pretty beefy. Magmotors are definitely a more traditional route.
But you can't buy battlebot style magmotors from the megmotor website without knowing exactly what they are - the A28 ampflow series that robot marketplace sells are designed specifically for combat robotics and have much higher specs than the standard motors magmotor sells. keep that in mind. If you're gonna buy magmotors, buy them from rmp cause those are the legit ones.
as far as sponsors go, the only company that consistently sponsored us was Witzco trailers - Josh Weinstein was our contact there. I believe his email is josh@witzco.com, but I don't remember.
We machined stuff at Hydrogel the last two years I was part of the team, but that was only because that's my dad's shop. He's not gonna let the team just come in and use his shop - it was only cause I was president and designed the bot and know how to machine stuff.
There's no set "rule" about how much you machine yourselves. Draw up the CAD files, send them off to be machined, and put the pieces together and you're good to go. It's kind of frowned upon by the teams who do machine everything themselves, but it's perfectly legal.
People Skills : 4164
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeWed Oct 20, 2010 5:43 am
I agree that shopping out parts is OK, but some folks don't like it.
On our team, I usually am the one to run the CNC, mostly because I don't want it screwed up. It's just too expensive to take a chance on. Typically, the students don't have time to really learn how to program it anyway.
The student's DO make parts in the DRO (direct readout, not Computer controlled) mode, with supervision.
I would LOVE to have one or two of them really make an effort to learn the programming, but they all want me to get the CAM software, so that they can go straight from SolidWorks to CNC. And I do want to get CAM working, but we have had so much trouble with the Tech people blocking our ability to install and alter things that it's been sitting here for 2 years UNUSED, and now we've lost the darn license!
Ryan McKinney
People Skills : 3341
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeThu Oct 28, 2010 5:46 pm
Update: A company with a very nice machine shop has agreed to machine our parts and/or teach us how to use the tools and let us do it. I plan on asking them for a significant amount of money soon, so hopefully that goes well. I'll also be meeting with possible local sponsors over the next three or four weeks.
Batteries are going inside the drum. Hopefully we'll be able to use A123s. I've got the battery mount pretty well designed but I haven't yet incorporated shock mounts/neoprene or whatever so I need to figure that out. Does anyone know a good way to shock mount batteries? Would neoprene foam rubber and UHMW do the trick?
No more slanted sides or back. Just a wedge on the front curving around the sides, but not right in front of the drum. Drum diameter is now at 10", wall thickness .5", length ~8 " depending on how wide the battery mount ends up being. I think we'll just cut shallow channels in the drum to put the s7 teeth in and then weld them in place.
possible bearing: Mcmaster part # 2721T2
I'm thinking 30 mm hardened 4340 shaft with a small hollow in the middle for the wires to run through.
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeThu Oct 28, 2010 6:06 pm
so you'll be charging the batteries inside the bot?
keep in mind you only are guaranteed 20 min between fight
Ryan McKinney
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeThu Oct 28, 2010 7:10 pm
Yeah I think we'd be charging the batteries while they're inside the drum. If we noticed something wrong with the bot's performance in the previous fight that indicated that some battery connection had broken, we would be able to get to the batteries but it would take 2 or 3 minutes minimum to do so.
Do you know if battery balancers are needed for charging A123s?
@Alex: Can you do that without decreasing the capacity of the batteries or hurting them in any way?
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeThu Oct 28, 2010 7:35 pm
ok so once you get it out of the arena back to your pits and everything situated and 15 min charge your right at your 20 minutes
Ryan McKinney
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeThu Oct 28, 2010 8:00 pm
Well...yes. We'll just have to practice and be like a nascar pit crew i guess.
If we do get the money then we could have an extra set of batteries that we switch out, and that would probably take 10 minutes total, but I doubt we'll end up with extra money.
Ryan McKinney
PostSubject: Update   120 lb. Drum Bot - Page 2 I_icon_minitimeSat Nov 06, 2010 6:48 pm
We got the SolidWorks software in the mail, $500 from a local company, and all the steel and aluminum we'll need for free from them as well.
For the design, we've ditched the batteries in the drum idea for multiple reasons, and I think for the weapon we'll be using 2 A28-150 magmotors instead of the A28-400, just because it fits better in the design and we can get the drum up to a higher speed. For speed controllers, we'll probably use IFI Victor 885's because we can't find any Victor HV-36's.
The drum's going to be 6 inches wide, this pipe: http://www.speedymetals.com/ps-3628-204-9-12-od-x-750-wall-dom-steel-tube.aspx
Does anyone happen to know roughly what the dimensions of the Victor 885 are? I can't find them online.
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeSun Nov 07, 2010 8:21 am
885's have the same dimensions as 883s
Ryan McKinney
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeSun Dec 05, 2010 1:36 pm
120 lb. Drum Bot - Page 2 Untitl11
Here's a cutaway top view.
We're going to put it in solidworks as soon as possible, but we're having some trouble with the software solidworks gave us...
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeMon Dec 06, 2010 5:45 am
Hmmm, that looks kinda like El Gran Rey Cholo.
Maybe I'll post a pic up here soon.
RemoteContact
People Skills : 3629
Registration date : 2009-10-15
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeMon Dec 06, 2010 6:20 pm
Actually it kind of looks like this lil' guy.'
120 lb. Drum Bot - Page 2 BotsIQ2010111
Ryan McKinney
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeMon Dec 06, 2010 6:44 pm
The big cholo king? lol ok i'd like to see that.
It seems a lot of robots look similar. but I admit the wedge and chassis design was inspired by K2.
@remote contact: a little bit. the weapon, weapon motor, and gearboxes are different, and ours is invertible. that one looks a lot like K2 actually
Ryan McKinney
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeFri Apr 08, 2011 7:11 pm
Here's what we've got so far. We're finishing it this weekend and shipping it out to Robogames monday. All of the machining is thanks to the guys at Sun Hydraulics. I'll post a pic of the CAD too eventually
120 lb. Drum Bot - Page 2 Photo10
120 lb. Drum Bot - Page 2 Drum_p12
People Skills : 3914
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeFri Apr 08, 2011 8:56 pm
the drum looks sweet
People Skills : 4160
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeFri Apr 08, 2011 9:30 pm
looks like your welding went well, look forward to seeing it completed
People Skills : 4845
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeFri Apr 08, 2011 9:41 pm
Looks fantastic. Should be interesting to see in operation.
jeeves_m_d
jeeves_m_d
People Skills : 4335
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeSat Apr 09, 2011 10:24 am
That looks freaking awesome! and its SHINY!
Stephen
Stephen
People Skills : 3857
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeSat Apr 09, 2011 4:46 pm
i dont know what type of cnc u have but i learned the basics its not that hard once u see the programing a few times
RemoteContact
PostSubject: Re: 120 lb. Drum Bot   120 lb. Drum Bot - Page 2 I_icon_minitimeTue Apr 12, 2011 12:41 pm
Robot looks great!!
120 lb. Drum Bot
Page 2 of 2Go to page : Previous  1, 2
Battlebots :: Team Update Pages :: Pine View Engineering Club-
