 Best type of Loctite to Bond metal?
Goto page : 1, 2  Next
Ryan McKinney
People Skills: 750
Registration date: 2010-07-20
PostSubject: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 6:16 pm
I know loctite is generally bad to use in robots, but in this case it was unavoidable, and it's not being used for anything structural. What's the best type of Loctite to bond aluminum to aluminum or aluminum to steel?
McMaster describes Loctite 430, 660, and 493 as very good for bonding metal but it doesn't say which is better.
People Skills: 2314
Registration date: 2009-03-14
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 6:24 pm
I would imagine an epoxy would be a better bet for something structural - a lot of loctites are very brittle.
People Skills: 3707
Registration date: 2009-03-16
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 6:25 pm
simple jb weld or metal epoxy would be my suggestion
Ryan McKinney
People Skills: 750
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 6:38 pm
I'll try the jb weld. Thanks
Alex Udanis
People Skills: 2637
Registration date: 2009-03-29
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 7:07 pm
Shoe Goo
Amazing Goop
Both of those are awesome all purpose adhesives.
AlexUdanis.com
http://www.alexudanis.com
People Skills: 3504
Registration date: 2009-03-31
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 9:50 pm
if it's of any importance, scrap it and do it right
Alex Udanis
People Skills: 2637
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 9:58 pm
Do it right out of 6-4!!!! HELLZ YEAHHH
AlexUdanis.com
People Skills: 3504
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 10:03 pm
My 12 melty can test all of your bondo joints for you....possibly adjust a few as well...bring it
Ryan McKinney
People Skills: 750
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 10:16 pm
I can't afford to scrap it and it's only an antweight sooo i'm going with the jb weld. The worst that can happen is a timing pulley doesn't hold on the shaft and goes spinning...and if that happens, I just need to drill a hole through timing pulley and shaft and put a pin in there, or maybe a threaded pin...and then jb weld it.
Alex Udanis
People Skills: 2637
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 10:19 pm
braze it.
AlexUdanis.com
Ryan McKinney
People Skills: 750
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 10:24 pm
With what? tin solder? the timing pulley and shaft are aluminum...
People Skills: 3504
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 10:25 pm
If it's just an ant, use an elastic band...should hold... affraid
O rings are my new favorite item
I use them to shock isolate batteries onmy little guys and a lot of other stuff.
They're cheap, they provide shock mounting and they let everything breath.....
I just don't use the for belt drives like a lot of others
Ryan McKinney
People Skills: 750
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 10:31 pm
elastic band? you're kidding right? it's a good idea for batteries i guess. The timing pulley is so small, and has no good attachment points, so my only option is either a pin through the whole thing (probably weakening the shaft) or an adhesive.
Alex Udanis
People Skills: 2637
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 10:34 pm
Braze it
AlexUdanis.com
Ryan McKinney
People Skills: 750
PostSubject: Re: Best type of Loctite to Bond metal?   Thu Oct 14, 2010 10:43 pm
What would I braze it with that's stronger than jb weld, and that has a lower melting point than aluminum? The only options I see are tin or lead (which aren't very strong), unless i used thin aluminum, but then I risk melting the timing pulley.
Page 1 of 2Goto page : 1, 2  Next
» should have some type of get together this holidays
» When's the HT Metal out!!!
» DYU Reviews (metal-archives.com)
» Winx Club Movie Clip:Heavy Metal! HQ!
» Best type of Loctite to Bond metal?
