| Author | Message |
turtle big contributor
People Skills: 720 Registration date: 2010-11-14 Age: 21 Location: hanover mass
 | Subject: Motor types Fri Dec 10, 2010 10:18 pm | |
| What do you guys use for drive motors in 15 pound Bots? my team has used both Banebots and gears. I like Banebots size but we have a problem with them burning out with the canisters they come with and when we upgrade the canisters we get slippage. Gears have proven themselves but they are just too large. so what do you guys use? thanks turtle |
People Skills: 3504 Registration date: 2009-03-31 Location: Miami
 | Subject: Re: Motor types Fri Dec 10, 2010 10:47 pm | |
| I might not be understanding what the problem is, but have you tried Triton motors, from an Emaxx?
They are a bit heavier, but also better.
What replacement motors have you tried?
Also, what voltage have you been running them at? _________________ Ready to Rumble combat robots Advisor to MLEC BotsIQ team...2010 BotsIQ champions (1st and 2nd places) Spinning Tortoise...Possibly the World's first Brushless Melty!! 2010 Franklin Cup winner Vapor bots..Ho
 | Subject: Re: Motor types Fri Dec 10, 2010 11:06 pm | |
| i used geared motors as my drive motors. we run our bot at 24 volts so the banebot motors we buy the canister always burns out. we bought new canisters that can handle the voltage but when we transfer the gearboxes they always end up slipping. In the past weve used gears motor as in the brand. they are very good and im happy with the performance but they are too big i would much prefer a motor the size of the banebot motors that can handle my voltage and perform well. does that clarify it? |
Alex Udanis Admin
People Skills: 2637 Registration date: 2009-03-29
 | Subject: Re: Motor types Sat Dec 11, 2010 1:08 am | |
| | turtle wrote: | | i used geared motors as my drive motors. we run our bot at 24 volts so the banebot motors we buy the canister always burns out. we bought new canisters that can handle the voltage but when we transfer the gearboxes they always end up slipping. In the past weve used gears motor as in the brand. they are very good and im happy with the performance but they are too big i would much prefer a motor the size of the banebot motors that can handle my voltage and perform well. does that clarify it? |
Canister? Maybe you should learn a bit more? _________________ AlexUdanis.com
 | Subject: Re: Motor types Sat Dec 11, 2010 11:46 am | |
| canister is the term i use for the brushed motor attached to a gear box pretty sure im not the only one that uses it but doesnt matter. if still confused check out the picture illl attempt to upload  |
 | Subject: Re: Motor types Sat Dec 11, 2010 1:13 pm | |
| On a few occasons, we've drilled and tapped the bb pinions to prevernt slippage.
Only a small portion of the teeth actually engage the planetary gears, so there is some room to do this.
24 volts might be beyond what most can motors can handle.
Any links to your 3rd party motors? _________________ Ready to Rumble combat robots Advisor to MLEC BotsIQ team...2010 BotsIQ champions (1st and 2nd places) Spinning Tortoise...Possibly the World's first Brushless Melty!! 2010 Franklin Cup winner Vapor bots..Ho
 | Subject: Re: Motor types Sat Dec 11, 2010 3:16 pm | |
| Pretty sure they are mabuchi rs 550 http://www.robotstorehk.com/rs_550pcvc.pdf im just trying to determine if theres a motor out there that performs as well as the gears with out being so large thanks for all the replies guys |
crowconor big contributor
People Skills: 672 Registration date: 2010-11-06
 | Subject: Re: Motor types Sat Dec 11, 2010 3:31 pm | |
 | Subject: Re: Motor types Sat Dec 11, 2010 5:50 pm | |
| thanks for confirming conor |
People Skills: 2314 Registration date: 2009-03-14 Age: 23 Location: Miami, FL / Atlanta, GA
 | Subject: Re: Motor types Sat Dec 11, 2010 6:06 pm | |
| I don't mean to be the annoying stickler here, but stop making threads in the wrong categories!
That said, previously a large number of teams have had good luck with just plain 550 series motors stripped out of the cheapest cordless drills they could find. If you really wanted to find some good brushed motors, I believe higher quality brushed motors are still made for RC planes, the only caveat being I have no experience using them. _________________ Georgia Institute of Technology - Mechanical Engineering RoboJackets Battlebots Team - Weapons Design Team Leader 09-10 President of RE Robotics 2005-2007
People Skills: 3707 Registration date: 2009-03-16
 | Subject: Re: Motor types Sat Dec 11, 2010 9:44 pm | |
| http://www.gearseds.com/competition_motor.html RJW those are the gears ed. motors. There was a team from mass. at nationals running them in there wedge and the seemed like they could take a beating Apparently juggernaut used them which also took a beating in its day.
Banebots dont like much more the 12v. These are probably the most commonly used motor/gearbox
There are tons of 550 motors with different winds that may hold up better. Theres also several modifications you can make to these to make the stronger, again look around this has all been talked about. We dont have problems responding to old threads. |
 | Subject: Re: Motor types Sun Dec 12, 2010 12:32 pm | |
| yah cody is right gears take a huge beating, i dont think we've ever broke one, am i right sean?, but they are sorta big. But they also can take alot of power. So i guess theres a give and take, and the team is bastoni's team, he's involved with gears. |
 | Subject: Re: Motor types Sun Dec 12, 2010 12:39 pm | |
| | crowconor wrote: | | and the team is bastoni's team, he's involved with gears. | he's a cofounder of gears |
 | Subject: Re: Motor types Sun Dec 12, 2010 12:44 pm | |
| yup, thats why we started using gears originally, cause our adviser, kurt giessler, is friends with bastoni and helped us out when we first stared battlebots. |
 | Subject: Re: Motor types Sun Dec 12, 2010 12:55 pm | |
| its funny that hometown hero was using maxons that werent holding up |
