| Motor types | |
turtle big contributor
People Skills : 5015 Registration date : 2010-11-14 Age : 33 Location : hanover mass
| Subject: Motor types Fri Dec 10, 2010 10:18 pm | |
| What do you guys use for drive motors in 15 pound Bots? my team has used both Banebots and gears. I like Banebots size but we have a problem with them burning out with the canisters they come with and when we upgrade the canisters we get slippage. Gears have proven themselves but they are just too large. so what do you guys use? thanks turtle | |
| Subject: Re: Motor types Fri Dec 10, 2010 10:47 pm | |
| I might not be understanding what the problem is, but have you tried Triton motors, from an Emaxx?
They are a bit heavier, but also better.
What replacement motors have you tried?
Also, what voltage have you been running them at? | |
| Subject: Re: Motor types Fri Dec 10, 2010 11:06 pm | |
| i used geared motors as my drive motors. we run our bot at 24 volts so the banebot motors we buy the canister always burns out. we bought new canisters that can handle the voltage but when we transfer the gearboxes they always end up slipping. In the past weve used gears motor as in the brand. they are very good and im happy with the performance but they are too big i would much prefer a motor the size of the banebot motors that can handle my voltage and perform well. does that clarify it? | |
| Subject: Re: Motor types Sat Dec 11, 2010 11:46 am | |
| canister is the term i use for the brushed motor attached to a gear box pretty sure im not the only one that uses it but doesnt matter. if still confused check out the picture illl attempt to upload | |
| Subject: Re: Motor types Sat Dec 11, 2010 1:13 pm | |
| On a few occasons, we've drilled and tapped the bb pinions to prevernt slippage.
Only a small portion of the teeth actually engage the planetary gears, so there is some room to do this.
24 volts might be beyond what most can motors can handle.
Any links to your 3rd party motors? | |
| Subject: Re: Motor types Sat Dec 11, 2010 3:16 pm | |
| Pretty sure they are mabuchi rs 550 http://www.robotstorehk.com/rs_550pcvc.pdf im just trying to determine if theres a motor out there that performs as well as the gears with out being so large thanks for all the replies guys | |
crowconor
People Skills : 4996 Registration date : 2010-11-06
| Subject: Re: Motor types Sat Dec 11, 2010 3:31 pm | |
| Subject: Re: Motor types Sat Dec 11, 2010 5:50 pm | |
| thanks for confirming conor | |
People Skills : 6547 Registration date : 2009-03-14 Age : 34 Location : Miami, FL / Atlanta, GA
| Subject: Re: Motor types Sat Dec 11, 2010 6:06 pm | |
| I don't mean to be the annoying stickler here, but stop making threads in the wrong categories!
That said, previously a large number of teams have had good luck with just plain 550 series motors stripped out of the cheapest cordless drills they could find. If you really wanted to find some good brushed motors, I believe higher quality brushed motors are still made for RC planes, the only caveat being I have no experience using them. | |
| Subject: Re: Motor types Sat Dec 11, 2010 9:44 pm | |
| http://www.gearseds.com/competition_motor.html RJW those are the gears ed. motors. There was a team from mass. at nationals running them in there wedge and the seemed like they could take a beating Apparently juggernaut used them which also took a beating in its day.
Banebots dont like much more the 12v. These are probably the most commonly used motor/gearbox
There are tons of 550 motors with different winds that may hold up better. Theres also several modifications you can make to these to make the stronger, again look around this has all been talked about. We dont have problems responding to old threads. | |
crowconor
| Subject: Re: Motor types Sun Dec 12, 2010 12:32 pm | |
| yah cody is right gears take a huge beating, i dont think we've ever broke one, am i right sean?, but they are sorta big. But they also can take alot of power. So i guess theres a give and take, and the team is bastoni's team, he's involved with gears. | |
| Subject: Re: Motor types Sun Dec 12, 2010 12:39 pm | |
| - crowconor wrote:
- and the team is bastoni's team, he's involved with gears.
he's a cofounder of gears | |
crowconor
| Subject: Re: Motor types Sun Dec 12, 2010 12:44 pm | |
| yup, thats why we started using gears originally, cause our adviser, kurt giessler, is friends with bastoni and helped us out when we first stared battlebots. | |
| Subject: Re: Motor types Sun Dec 12, 2010 12:55 pm | |
| its funny that hometown hero was using maxons that werent holding up | |
crowconor
| Subject: Re: Motor types Sun Dec 12, 2010 12:56 pm | |
| yah i saw that, especially cause they probably get gears for free? | |
| Subject: Re: Motor types Sun Dec 12, 2010 1:44 pm | |
| we have broken gears actually weve broken muliple all the ones that are colored red are broken either electronic problems or once we actually broke the gears inside it but even with this problems they are still the best motors weve used i just want something smaller | |
crowconor
| Subject: Re: Motor types Sun Dec 12, 2010 1:58 pm | |
| well i meant us, the younger kids have broken them right? | |
| Subject: Re: Motor types Sun Dec 12, 2010 2:00 pm | |
| the electronic problems have mostly been the younger kids we still have some with messed up electronics from before we joined the team too but the broken gears was from the bloomsburg match in san fran | |
crowconor
| Subject: Re: Motor types Sun Dec 12, 2010 2:02 pm | |
| Subject: Re: Motor types Sun Dec 12, 2010 2:18 pm | |
| an electonics problem is completly seperate from the motor. I never looked into it before but the gears ESC is just a banebots controller with plugs on it. These contollers will not last very long with more then 12 volts | |
crowconor
| Subject: Re: Motor types Sun Dec 12, 2010 2:19 pm | |
| yah the banebots and gears are the same esc.. we run them at 24 and they work fine | |
| Subject: Re: Motor types Sun Dec 12, 2010 2:20 pm | |
| im saying more like the plugs being torn out the back and the brush part of the motor actually breaking or becoming disconnected | |
| Subject: Re: Motor types Sun Dec 12, 2010 2:23 pm | |
| how many matches to you get out of them at 24v? | |
crowconor
| Subject: Re: Motor types Sun Dec 12, 2010 2:32 pm | |
| alot, its not often it happens, to be honest i sorta think they can be crappy think some just arent made as well as others, and some blow, but the ones i have on my bot now ive for probably had 10+ matches | |
| Subject: Re: Motor types Mon Dec 13, 2010 6:56 am | |
| This is remarkable news to me. Our experience with BB12-45's is that anything over 3S Lipo (14.8 V) causes them to overheat and stop working. Once they cool back down, they work fine, but by then you've lost the match.
What sort of setup are you using: receiver, battery, gearmotor, wheel? | |
| Subject: Re: Motor types | |
| Motor types | |
