Belt Pitch 5 5 1
 Belt Pitch
Goto page : 1, 2  Next
crowconor
People Skills: 672
Registration date: 2010-11-06
PostSubject: Belt Pitch   Wed Jan 19, 2011 1:38 pm
hey guys we were thinking about trying timing belts for our drums, so my question is what pitch do you use? I know you have to design around the belt because it isnt one size fits all, also any other suggestions? We use a 1:2 ratio
jeeves_m_d
People Skills: 1736
Registration date: 2009-04-21
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 2:37 pm
Typically not the way to go....
Alot of teams use inverted timing belt because its just a flat belt
Timing belts used normally will get you up to speed quicker even as the belt get a little loose. but they put an unnecesarry shock through to the motor which will result in greater current spikes during hits.
What we have used for timing belts in weapons have been XL series belts 0.2'' pitch, but we inverted them
crowconor
People Skills: 672
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 2:52 pm
what do you mean inverted?
Alex Udanis
People Skills: 2637
Registration date: 2009-03-29
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 2:54 pm
At plum we used "L" sized inverted and normal.
AlexUdanis.com
http://www.alexudanis.com
crowconor
People Skills: 672
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 2:57 pm
inverted as in like in side out? so the teeth aren't touching the gears?
People Skills: 3504
Registration date: 2009-03-31
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 3:02 pm
That is what it means
crowconor
People Skills: 672
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 3:14 pm
do you still use timing pulleys? Is it bad to use them as you normally would, I know jeeves explained why not to, but will it wreck the motor? Do they slip alot when inverted?
People Skills: 3707
Registration date: 2009-03-16
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 3:51 pm
We've used the both ways, never had any motor problems and we've snapped them both ways from REALLY big hits, usually a drive belt would snap before or along with it
People Skills: 3504
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 4:09 pm
inverted timing belts are used with smooth pulleys.
You do need a tensioning system of some sort.
We usually set them with a bit of looseness, so that things can slip a little on hits.
crowconor
People Skills: 672
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 4:39 pm
i'm thinking of trying xl pitch normally, do you think that would be okay? or go with L?
jeeves_m_d
People Skills: 1736
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 6:49 pm
It will be fine, but you may find that when the belt doesn't slip on big hits, and the motor stalls or slow siginifigantly that it will draw ALOT more current then your used to, and depending on how the rest of the bot is wired you may heat stuff up and take away power from your drive. Granted this is only for a short amount of time but it still is a risk, after a big hit you want to show that you didn't take yourself out.
Alex Udanis
People Skills: 2637
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 7:01 pm
The biggest thing if your running it inverted is the belt width. At plum we used 1/2" wide belts
AlexUdanis.com
People Skills: 1569
Registration date: 2009-06-10
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 8:44 pm
XL series belts are commonly used, both inverted and not. 3/8 wide or 1/2 wide are also the most common. I had thought (before reading this thread) that weapons were almost always run inverted, and drive was almost always with 'teeth in." Clearly, this is not always the case. The advantage of 'teeth in' is that the center distance calculators will give accurate values, and you never have to make your own pulley. Inverted has the advantage of slip (and really, you can use the toothed pulleys, but you don't have to). Inverted does NOT work with the center distance calculators, so making your own pulleys is one way to 'guess and check' your way to the proper fit.
Will Bales' Fluffy uses THREE 3/8 wide inverted belts at a 3:1 ratio. The big problem with his implementation is 'teeth in mesh'--that is, his small smooth drive pulley is very close to his large output pulley, so there isn't much contact on the small pulley, so it slips easily. He used three side-by-side to offset this effect, and for redundancy because he has a 5 horsepower motor driving the darn thing.
Yes, you read that right, FIVE horsepower in a 15lb weapon. I am gonna miss that crazy guy when he graduates this spring. . .
People Skills: 3504
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 8:57 pm
IIRC the mamba monsters claim 5hp output as well????
People Skills: 3504
PostSubject: Re: Belt Pitch   Wed Jan 19, 2011 9:00 pm
here is quote from the castle wesbsite
"Mamba Monster systems typically pull 4,000-5,000 watts (5 to 6 horsepower) under acceleration"
I also noticed that they now have a 1/5 scale setup as well....where will it end?? can you say 10hp?
Belt Pitch
Page 1 of 2Goto page : 1, 2  Next
» Belt Pitch
» Round Urethane Belt Drive
» FCW getting their own Divas Belt!
» Cocky Belt Buckle!
» Looking for Sith Boots and a Sith Belt.
