Subject: Miss Fortune-Featherweight Tue Feb 15, 2011 9:48 am
getting close,
still left to do mount idler pulley, mount ti wedge, make some skids so it can handle motos floor, and then i should be ready for this weekend
Subject: Re: Miss Fortune-Featherweight Tue Feb 15, 2011 1:07 pm
30 Looks pretty sick!
crowconor
People Skills : 4996 Registration date : 2010-11-06
Subject: Re: Miss Fortune-Featherweight Tue Feb 15, 2011 1:53 pm
looks real good! is the belt for the drum going to fit threw that hole though? looks small, ,maybe its thee angle?
Subject: Re: Miss Fortune-Featherweight Tue Feb 15, 2011 3:19 pm
i have to finish the idler mount then the belt will fit and hold nice tension
Subject: Re: Miss Fortune-Featherweight Tue Feb 15, 2011 4:44 pm
Are you going to run the belt inverted? If the idler is mounted to the frame rail (guessing?) your going to have a lot of contact area on the weapon pulley, seems like it'd be a good application
Subject: Re: Miss Fortune-Featherweight Tue Feb 15, 2011 10:22 pm
probable going to run inverted till belt stretches out and becomes more flexible. with the belts being brand new their pretty stiff yet and put a lot of pressure on the motor. don't really how well its going to run yet, i hope to get time to play with it in the box on friday
Subject: Re: Miss Fortune-Featherweight Mon Feb 28, 2011 4:29 pm
How did this do at Moto?
Haven't heard anything and seems like you haven't put up ANY video?
Subject: Re: Miss Fortune-Featherweight Mon Feb 28, 2011 5:10 pm
Wicked fight against sloth. Whoever started building miss fortune before used a non conventional way of mounting the beater that the horizontal bar of sloth had the better of. Sorry kyle Ill let you finish
Subject: Re: Miss Fortune-Featherweight Mon Feb 28, 2011 5:18 pm
I saw that in the pictures...looked like a Josh Rachel type of shaftless beater deal??
Did the beater pop out?
Subject: Re: Miss Fortune-Featherweight Mon Feb 28, 2011 5:24 pm
Yup, Kyle showed me what had happend. Who ever designed/started the build had planned to run screws into to shaft numbs through the frame rails to prevent what happened from happening. But he drilled the holes off center
Subject: Re: Miss Fortune-Featherweight Mon Feb 28, 2011 5:37 pm
good fight
He was beating the heck out of sloth until the unfortunate yet predictable meltdown
Subject: Re: Miss Fortune-Featherweight Tue Mar 01, 2011 10:22 pm
ya i had a solution to that but the bolt holes that were drilled in the shafts of the beater were off center, so when i went to put bolts in it they rubbed agenst the holes i drilled in the frame. i was worried there would be to much friction to start up so i ran without them.
and ya i have alot of video but i haven't even had the time to look through and name everything yet, let alone upload it. sorry school and poo
Stephen super contributor
People Skills : 5587 Registration date : 2009-11-01 Age : 29 Location : West Mifflin
Subject: Re: Miss Fortune-Featherweight Wed Mar 02, 2011 5:53 pm
what r the sides made out of it doesnt look like aluminium is it s7
Subject: Re: Miss Fortune-Featherweight Thu Mar 03, 2011 9:36 am
