| Thin titanium fbs shell tooth shear questions | |
People Skills : 5112 Registration date : 2011-02-05 Age : 33 Location : towson md
| Subject: Thin titanium fbs shell tooth shear questions Fri May 06, 2011 1:22 pm | |
| I have just bought two titanium shells for my antweight fbs. They are really thin like 1mm so my question is without destroying it by pulling the teeth out on hits, would it be better to use one 1/4 bolt per tooth or to use like 5 m3's with washers it's size is 7.5" diameter and .75" tall and the teeth will weigh about half an ounce each and if it means anything i will be spinning it at around 7500k teeth will be .75" long by 1" heat treated steel angle any suggestions welcome good or bad | |
People Skills : 5004 Registration date : 2011-03-30 Location : south west pa
| Subject: Re: Thin titanium fbs shell tooth shear questions Fri May 06, 2011 2:05 pm | |
| stay away from number 3 metric screw, i have had nothing but trouble with them, your best bet is probably to get a grade 8 machine screw- like 6-32 or 8-32 and use how ever many fit, the more screws means the same force applied over more bodies, which in turn lightens the overall strain on an individual screw | |
People Skills : 5921 Registration date : 2009-07-05 Age : 33 Location : PA
| Subject: Re: Thin titanium fbs shell tooth shear questions Fri May 06, 2011 7:02 pm | |
| just back the screws with a 1/16" piece of aluminum or something | |
| Subject: Re: Thin titanium fbs shell tooth shear questions Sat May 07, 2011 10:20 am | |
People Skills : 4913 Registration date : 2011-04-10 Age : 29 Location : Blaine Minnesota
| Subject: Re: Thin titanium fbs shell tooth shear questions Sat May 07, 2011 11:17 am | |
| i have a similar question...should i use pieces of aluminum or washers to help spread the weight of a two-piece frame? i'm assuming most of the force of the impact from hits will transfer to one of the 6 spots i'm pointing at, or to the top of those pieces. what should i do here? here is a pic of it, https://i.servimg.com/u/f24/16/44/64/39/img_2814.jpg also! just finished downloading autodesk 3DS max. best manmade tool EVER. | |
| Subject: Re: Thin titanium fbs shell tooth shear questions Sat May 07, 2011 11:55 am | |
| im no artist either but.... i suggest using the squares on that graph paper as a scale reference wether it be 1/4" scale or 1/8" it helps alot when drafting and if you would like i can show you how to do 3d on paper using a vantage point and scale vector.
otherwise if you have the space washers helped me disperse the load of small m3's or use another piece of garolite as a washer if you choose to use that material
| Subject: Re: Thin titanium fbs shell tooth shear questions Sat May 07, 2011 9:19 pm | |
| really you should be ok with either or but washers might be easier to manipulate because when you get into one piece assemblies you tend to have to have everything lined up exactly, with washers you have some flexibility with alignment
| Subject: Re: Thin titanium fbs shell tooth shear questions Wed May 11, 2011 12:47 am | |
| so the shell came in the mail yesturday and it seems like i need a stress relief point where the tooth mounts because the ti is is thin im thinking rivits | |
| Subject: Re: Thin titanium fbs shell tooth shear questions | |
