 Best way to screw into UHMW
Self-tapping Screw
50%
 50% [ 1 ]
Machine Screw
50%
 50% [ 1 ]
Total Votes : 2
Alex Udanis
People Skills: 2637
Registration date: 2009-03-29
PostSubject: Best way to screw into UHMW   Sun May 08, 2011 12:20 pm
Hey I've never worked with UHMW before and need some help
What is the best way to hold a UHMW frame together? Self-tapping screws? Or to tap the UHMW and thread machine screws into it?
Thanks
-Alex
AlexUdanis.com
http://www.alexudanis.com
People Skills: 1594
Registration date: 2009-07-05
PostSubject: Re: Best way to screw into UHMW   Sun May 08, 2011 12:23 pm
i generally use a combination of wood screws and machine screws. i use the wood screws to hold major framing sections together and machine screws for stuff like the top and bottom plates
Camden W
People Skills: 728
Registration date: 2011-04-10
PostSubject: Re: Best way to screw into UHMW   Sun May 08, 2011 2:04 pm
what if the top and bottom plates WERE the major framing pieces?
Alex Udanis
People Skills: 2637
PostSubject: Re: Best way to screw into UHMW   Sun May 08, 2011 2:10 pm
I would imagine that self tapping screws shouldn't be removed and screwed back in as much without enlarging the hole. If you going to keep taking something on and off I would say machine screws would be best.
AlexUdanis.com
Camden W
People Skills: 728
PostSubject: Re: Best way to screw into UHMW   Sun May 08, 2011 2:19 pm
sounds good.
People Skills: 3504
Registration date: 2009-03-31
PostSubject: Re: Best way to screw into UHMW   Sun May 08, 2011 3:09 pm
captive nuts? or nut strips of some sort, might help solve wear problems and povide more of a bearing surface?
Alex Udanis
People Skills: 2637
PostSubject: Re: Best way to screw into UHMW   Sun May 08, 2011 3:19 pm
I entirely didn't realize I could do that, but it seems very logical. After looking in to those on Master Carr, I found that they made special helicoils just for plastics those seem like they would work perfect. You would get the holding power of the wood/plastic screws, with the removability of a machine screw! I know what I am using!
AlexUdanis.com
Koensig
People Skills: 533
Registration date: 2011-02-25
PostSubject: Re: Best way to screw into UHMW   Sun May 08, 2011 4:00 pm
Those seem really nice. I'm gonna have have to get some of those.
People Skills: 1594
PostSubject: Re: Best way to screw into UHMW   Sun May 08, 2011 4:02 pm
there is also these http://www.mcmaster.com/#tee-nuts/=c7w2oi
i used them to attach the tooth breaker bar on the bot i made for Brandon Nicholes
» Best way to screw into UHMW
» Set screw tips
» Worn and Loctited Set Screw Removal
» How well does uhmw holds threads?
» HDPE compared to UHMW for ramping
