 Alternative Competition Styles
People Skills : 4716
PostSubject: Alternative Competition Styles   Tue Mar 31, 2009 10:47 pm
What got me thinking about this was the RioBotz tutorial where the author(s) describe a tournament they attended in Brazil where the standard arena walls were built onto a skating rink, with a floor of solid ice. This created some different challenges for the teams to design around, as well as being an interesting venue.
This topic could be treated sort of like the Idea Dump thread, but for potential new competition and arena styles that diverge from the typical Battlebots format.
Sean Rubin
Prezerdent of Sexxi Cuddlemen
People Skills : 4013
PostSubject: Re: Alternative Competition Styles   Tue Mar 31, 2009 10:57 pm
An arena in a volcano. Or above. A challenge to make your robot withstand that much heat. Smile
PostSubject: Re: Alternative Competition Styles   Tue Mar 31, 2009 11:14 pm
Could hold it with the arena outdoors in the desert regions of California or in Phoenix, Arizona in the summer... the greenhouse effect from the arena would put temps inside WAY above 150F.
People Skills : 6181
PostSubject: Re: Alternative Competition Styles   Tue Mar 31, 2009 11:17 pm
please tell me what ESCs could handle that hahha
PostSubject: Re: Alternative Competition Styles   Tue Mar 31, 2009 11:19 pm
Ones with gigantic, pre-cooled heat sinks, that's what.
That Guy
samurai jesus
samurai jesus
People Skills : 4088
PostSubject: Re: Alternative Competition Styles   Tue Mar 31, 2009 11:44 pm
A refrigerator bot.
PostSubject: Re: Alternative Competition Styles   Tue Mar 31, 2009 11:47 pm
And theres the reason Battlebots died hahahahaha
And heat sinks would only decipate the heat from the processor/board, it wouldnt help with the actual temperature at all Sad
PostSubject: Re: Alternative Competition Styles   Tue Mar 31, 2009 11:51 pm
@ Cody: True, you still have your motors to worry about, but it's not impossible for electronics to be tuned to operate in temperature extremes. At least the wheels would have good grip, they'd be softened by the heat Laughing.
Actually, what if you took a small copper heat sink, drilled a hole of a certain size to depth, and tapped that hole a certain distance for a bolt with a rubber O-Ring around the base of its head. Then, make a small slug of ice that will fit in the non-tapped portion, and super-cool it before a match with an alcohol bath cooled by dry ice to some obscenely low temperature. Place ice slug into heat sink, seal, and turn on the robot - it should do a perfect job of keeping the ESCs at a happy temperature for well over the standard match length.
Dughi's refrigerator 'bot might also be an approach - insulating the robot and adding some kind of cooling system, at least to the section of the robot housing the ESCs.
PostSubject: Re: Alternative Competition Styles   Tue Mar 31, 2009 11:56 pm
Refrigerator bots cause the demise of battlebots basically! haha
What about dipping speed controlers in liguid nitrogen, do you think they would short?!
PostSubject: Re: Alternative Competition Styles   Thu Apr 16, 2009 7:41 pm
Mythbusters Pykrete Episode
So i was watching mythbusters last night and the myth they were testing made me think of this haha
They were testing this composite material called Pykrete.
Pykrete is a mix of sawdust/wood pulp and ice.
Mythbusters did several test to find the Pykrete is actually bullet proof while they ran out of weights after 300 hundred pounds when the similar ice slab was somewhere near 40 pounds i believe.
You could make a mold of your frame and make multiples for each match(thinking that you could self-tap into the material) and the frozen frame would cool you electronics!
hahahahahahahaha crazy stuff they built a freakin boat out of it! then it melted Crying or Very sad
Only video i could find right now
Sean Rubin
PostSubject: Re: Alternative Competition Styles   Thu Apr 16, 2009 11:05 pm
It is bullet proof...but not necessarily spinning bar proof or sharp edge proof. I know many bullet proof vests that you can just cut right through them with scissors...but bullets dont penetrate them.
PostSubject: Re: Alternative Competition Styles   Thu Apr 16, 2009 11:11 pm
Pykrete is highly crush resistant. The first time it was demonstrated to a group of generals, the inventor shot it with a pistol; the bullet then ricocheted off the small block and hit one of the assembled generals in the leg. Fortunately, that was enough to impress the assembled group (including the guy who got hit) and the inventor got much more funding toward pykrete research.
PostSubject: Re: Alternative Competition Styles   Thu Apr 16, 2009 11:56 pm
It proved its strength and id have to think it would just turn into an ice machine against a drum Very Happy
PostSubject: Re: Alternative Competition Styles   Fri Apr 17, 2009 12:31 am
OOOOOO i completly forgot about this!
IDk if anyone else watched discovery channel last night but there was a new show calle pitchmen and they introduced ImpactGel
Looks pretty cool tho
Great way to mount stuff in your pykrete bot! Razz
Sean Rubin
PostSubject: Re: Alternative Competition Styles   Fri Apr 17, 2009 5:51 pm
I LOVE BILLY MAYS!! He can sell a piece of poo by calling it WowPoo!
PostSubject: Re: Alternative Competition Styles   Fri Apr 17, 2009 6:51 pm
As long as you can wash it and sell it for only $19.99
BUT WAIT THERES MORE!!!!!
Note: i just held down both my shift buttons at the same time and i have no clue why, i guess that was just that enthusiastic lol
That Guy
samurai jesus
samurai jesus
PostSubject: Re: Alternative Competition Styles   Fri Apr 17, 2009 11:21 pm
Ya BILLY MAYS is training a successor.
People Skills : 4429
PostSubject: Re: Alternative Competition Styles   Sat Apr 18, 2009 12:24 pm
hahaha dude. there should be a DOUBLESHIFT function for really excited people. like it makes the font bigger or bold or something lol...
hahahaha that just made my day
PostSubject: Re: Alternative Competition Styles   Sat Apr 18, 2009 2:28 pm
I typed it, realized what i had just done, and sat pondering WTF i had just done
» Restless Dead Alternative Warband?
» Scandinavian MCM Styles
» Alternative Apple Crumble
» APPLE: Alternative Apple Crumble
» Mai-HiME Alternative Ending?
Battlebots :: Bots :: General Discussion-
