 UHMW question
Riggz
People Skills : 2553
PostSubject: UHMW question   Sun Oct 30, 2011 11:17 pm
Has anyone had experience with pressing a bearing into UHMW? I am not familiar enough with the material and figured someone here would know something about it. Smile
Camden W
People Skills : 2959
PostSubject: Re: UHMW question   Mon Oct 31, 2011 1:43 am
I assume it would be just like any other material where you could press fit and/or superglue it in place, or at least that's what I plan on doing with the stuff.
People Skills : 3712
PostSubject: Re: UHMW question   Mon Oct 31, 2011 8:35 am
if you can dead shaft for you design that would be the best option. if not the wider the material and the wider the bearing, the better. you will also want to put collars or something on both sides of the bearing that are larger then the hole to try and prevent the bearing from going anywhere at least without the entire shaft collar being pulled through the hole witch is unlikely.
-Kyle
Riggz
PostSubject: Re: UHMW question   Wed Nov 02, 2011 11:07 pm
thanks!
UHMW question
» Question About Gladiator beasts.
» Dark Fusion / Mirror Force question
» Question about Reinforce Truth
» Question on scrap dragon
» Ginkgo Question
