 Another UHMW question
Riggz
People Skills : 2613
PostSubject: Another UHMW question   Sat Nov 26, 2011 11:19 pm
Our machinist sponsor is questioning whether or not they can mill UHMW for our team. They are afraid of melting the material. We might have to do this inhouse. Our shop however is limited to a techno router that only lowers to 10,000 rpm for spindle speed. Am I going to be able to do this at our shop? If so, how should I go about it?
MikeNCR
People Skills : 3653
PostSubject: Re: Another UHMW question   Sun Nov 27, 2011 1:07 am
http://www.cncplastics.com/PDFs/MACHINING%20UHMW.pdf
"Milling: Cutters designed for machining aluminum give the best results. Cutting speeds of 600 to 1,800 feet per minute are suggested, with a feed rate of approximately .01 inches per revolution. Router bits work well for slotting and light milling."
The stuff's fantastic to mill.
http://nearchaos.net
People Skills : 3535
PostSubject: Re: Another UHMW question   Thu Dec 01, 2011 1:00 pm
They can mill it.... Just slow it down or add some juice... Usually it is not the melting but the fraying that is worried about.
People Skills : 3772
PostSubject: Re: Another UHMW question   Thu Dec 01, 2011 5:52 pm
the fraying depends on it your climb cutting or conventional cutting. climb cutting will give you the little fuzzes and conventional cutting usually gives you a clean finish.
Riggz
PostSubject: Re: Another UHMW question   Thu Dec 01, 2011 6:00 pm
Thanks guys!
» Question About Gladiator beasts.
» Dark Fusion / Mirror Force question
» Question about Reinforce Truth
» Question on scrap dragon
» Ginkgo Question
