 Belts and pulley suggestions
saylor23
People Skills : 2738
PostSubject: Belts and pulley suggestions   Tue Jan 03, 2012 7:11 pm
Building a 15 lb bots in my class, drum weapon, around 3.5 lbs, mamba monster for weapon motor, we are planning a 1" pulley on motor 3"on drum, what suggestions for belts and pulley, one or two belts, a post from a guy from Canada that made or sold belts, ring any bells, Timing pulley and belts??? We can make smooth or v-belt pulleys?
Planning on 12-15K rpm on the drum
People Skills : 3580
PostSubject: Re: Belts and pulley suggestions   Tue Jan 03, 2012 8:49 pm
I would recommend L series timing pulleys with neoprene belts, or a smooth pulley could work too.
saylor23
PostSubject: Re: Belts and pulley suggestions   Wed Jan 04, 2012 9:31 pm
should we flip the belts ?
PostSubject: Re: Belts and pulley suggestions   Wed Jan 04, 2012 10:30 pm
you really shouldnt have to unless the drum is a 5inch od
if you have a outer support for your weapon motor shaft I would use the teeth with a kevlar belt but if it doesnt I would go with a inverted neoprene belt
saylor23
PostSubject: Re: Belts and pulley suggestions   Thu Jan 05, 2012 9:49 pm
Why 5" OD, why will that change things?
PostSubject: Re: Belts and pulley suggestions   Thu Jan 05, 2012 10:29 pm
because your more likely of getting a big bite on bigger weapons and would put more stress on the belt, but beaters tend to do that more than drums.
saylor23
PostSubject: Re: Belts and pulley suggestions   Fri Jan 06, 2012 9:08 am
So you want to flip the belt will a large weapon? or is that to big a weapon 5" for a Bots IQ class
PostSubject: Re: Belts and pulley suggestions   Fri Jan 06, 2012 10:20 pm
well whats the od of your drum going to be
saylor23
PostSubject: Re: Belts and pulley suggestions   Sat Jan 07, 2012 7:42 am
5.5"
PostSubject: Re: Belts and pulley suggestions   Sat Jan 07, 2012 10:04 am
on a 5.5 i would run a inverted neoprene belt
» F.S BBK Underdrive pulley/Impala Grill
» Underdrive pulley or not?
» VTA Low-Gain Preamp Tube Suggestions...
» PAS back panel rewire
» symfo's system (new member)
