| Belts and pulley suggestions | |
saylor23
People Skills : 4849 Registration date : 2011-04-15 Age : 57 Location : Windber,PA
| Subject: Belts and pulley suggestions Tue Jan 03, 2012 7:11 pm | |
| Building a 15 lb bots in my class, drum weapon, around 3.5 lbs, mamba monster for weapon motor, we are planning a 1" pulley on motor 3"on drum, what suggestions for belts and pulley, one or two belts, a post from a guy from Canada that made or sold belts, ring any bells, Timing pulley and belts??? We can make smooth or v-belt pulleys?
Planning on 12-15K rpm on the drum | |
People Skills : 5609 Registration date : 2009-12-24 Age : 29 Location : Plum,Pa
| Subject: Re: Belts and pulley suggestions Tue Jan 03, 2012 8:49 pm | |
| I would recommend L series timing pulleys with neoprene belts, or a smooth pulley could work too. | |
saylor23
| Subject: Re: Belts and pulley suggestions Wed Jan 04, 2012 9:31 pm | |
| should we flip the belts ? | |
| Subject: Re: Belts and pulley suggestions Wed Jan 04, 2012 10:30 pm | |
| you really shouldnt have to unless the drum is a 5inch od
if you have a outer support for your weapon motor shaft I would use the teeth with a kevlar belt but if it doesnt I would go with a inverted neoprene belt | |
saylor23
| Subject: Re: Belts and pulley suggestions Thu Jan 05, 2012 9:49 pm | |
| Why 5" OD, why will that change things? | |
| Subject: Re: Belts and pulley suggestions Thu Jan 05, 2012 10:29 pm | |
| because your more likely of getting a big bite on bigger weapons and would put more stress on the belt, but beaters tend to do that more than drums. | |
saylor23
| Subject: Re: Belts and pulley suggestions Fri Jan 06, 2012 9:08 am | |
| So you want to flip the belt will a large weapon? or is that to big a weapon 5" for a Bots IQ class | |
| Subject: Re: Belts and pulley suggestions Fri Jan 06, 2012 10:20 pm | |
| well whats the od of your drum going to be | |
saylor23
| Subject: Re: Belts and pulley suggestions Sat Jan 07, 2012 7:42 am | |
| Subject: Re: Belts and pulley suggestions Sat Jan 07, 2012 10:04 am | |
| on a 5.5 i would run a inverted neoprene belt | |
| Subject: Re: Belts and pulley suggestions | |
