| Team Ignition-FireArrow | |
Badnik96
People Skills : 4298 Registration date : 2012-08-19 Age : 26 Location : Connecticut
| Subject: Team Ignition-FireArrow Wed Jun 05, 2013 6:10 pm | |
| Yep, this is the thread for my first ever antweight project, FireArrow. Got bored today, made a cardboard mockup of the armor and stuff sorry for the blurry pic, it was rushed | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Thu Jun 06, 2013 9:23 am | |
| Let's see, I'm using Lite Flites, Fingertech Silver Sparks, TinyESCs, a Spektrum radio system and an E-Flite battery. Currently have everything but the battery and charger. | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Thu Jun 06, 2013 9:17 pm | |
| I have the 33.3:1 Silver Sparks, and this is the battery I've chosen. Still waiting for the battery to be restocked though... Also colored in the mockup, just so everyone can see what the paintjob will look like... | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Thu Jun 06, 2013 10:11 pm | |
| Yeah, but it's already ordered. I guess we could cancel it or something but it seems like too much of a hassle. | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Sat Jun 08, 2013 7:35 pm | |
| Got some of the aluminum cut and milled today. | |
Joe Doerfler
People Skills : 4348 Registration date : 2012-07-02 Age : 26 Location : Plum, PA
| Subject: Re: Team Ignition-FireArrow Sat Jun 08, 2013 8:15 pm | |
| Why not some thin titanium | |
Joe Doerfler
| Subject: Re: Team Ignition-FireArrow Sat Jun 08, 2013 10:02 pm | |
| No yah I know what you mean but I was just wondering why | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Sun Jun 09, 2013 12:46 pm | |
| TBH I dunno, I was recommended aluminum. | |
Joe Doerfler
| Subject: Re: Team Ignition-FireArrow Sun Jun 09, 2013 2:25 pm | |
| ok theres nothing wrong with aluminum as ur wedge since its a 1 pounder because theres not a lot of weaponed bots | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Sun Jun 09, 2013 3:04 pm | |
| That's true, there's only one spinner registered for Bot Blast as of yet
maybe next year I'll be able to coax my parents to get some titanium, idk | |
Joe Doerfler
| Subject: Re: Team Ignition-FireArrow Sun Jun 09, 2013 5:31 pm | |
| You really shouldn't need a lot and how much does that piece of aluminum weight because you could probably use .050 | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Sun Jun 09, 2013 7:30 pm | |
| We're using .06" right now.. | |
Joe Doerfler
| Subject: Re: Team Ignition-FireArrow Mon Jun 10, 2013 11:17 am | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Sat Jun 15, 2013 2:52 pm | |
People Skills : 4920 Registration date : 2011-04-10 Age : 29 Location : Blaine Minnesota
| Subject: Re: Team Ignition-FireArrow Sun Jun 16, 2013 7:46 pm | |
| My bot used that exact same battery for a while, but I abuse mine with accidental shorting/peak charging only, and ended up with a dead cell after about 2 weeks of testing. You should see about 10-15 minutes out of that battery per charge. | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Sun Jun 16, 2013 9:05 pm | |
| Actually we canceled the order on that battery (because it was taking forever to restock) and got a Hobbyking Nanotech to go along with the charger instead. | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Tue Jun 25, 2013 3:31 pm | |
| And the battery/charger came yesterday!
We also drilled some holes in the side plates to mount the motors. I'll post pics once I get them off my camera. | |
| Subject: Re: Team Ignition-FireArrow Tue Jun 25, 2013 5:46 pm | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Sat Jun 29, 2013 3:26 pm | |
| Everything but the wedge is attached at this point. (observant people may spot a piece of scotch tape I used to attach the wedge for the photo). Also the switch is currently installed, but none of the wiring is done. | |
| Subject: Re: Team Ignition-FireArrow Sun Jun 30, 2013 4:57 pm | |
| The wiring is the hardest part In my opinion Fancy little wedge you got there! when it's done, try closing doors with it | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Fri Jul 05, 2013 6:02 pm | |
| Thanks man Bent back the sides of the wedge for more spinner resistance. Also made the wedge more flush and got some holes up top for the screws that are supposed to go there. | |
| Subject: Re: Team Ignition-FireArrow Sat Jul 06, 2013 12:32 am | |
| Nice progress :3 Also, a few tips. For the bent sides, always make sure they are far away from the blade of a spinner. if it's clockwise, don't let it near the left of your bot, and always try to face the leading edge of the weapon. For uppercutters, aim for them at an angle so they can't get a good head-on bite. As for your wedge, I suggest driving it on concrete or other abrasive surface until it looks something like this image. tape some weights to the front to speed up the process. As for testing purposes, your bot should be able to withstand a heavy smack with a hammer from behind the wedge. Extra weight should be distributed towards the center of the bot so as to maintain grip while having a heavier and lower front end than the competition. Unfortunetely, I have no experience in the matter yet, but I believe most of what i said is true XD | |
Badnik96
| Subject: Re: Team Ignition-FireArrow Sat Jul 06, 2013 3:57 am | |
| I know most of that The plan was to indeed make the wedge flush. I think that's what I'm going to end up doing next. | |
Badnik96
| Subject: Re: Team Ignition-FireArrow | |
