 Balance lead problems
saylor23
People Skills : 2621
PostSubject: Balance lead problems   Wed Sep 12, 2012 9:15 pm
We made three 5 cell A123 packs for last years bot, they worked fine except we can not get them to balance, they charge, but if we try to balance and charge we get an error, if we just charge they work fine, I feel balance lead problems, to plug into the EH board, one red and 5 black leads, should the red lead be in the top or negative spot, it is not , do I move it? Will not read any amps going in on display the way it is now? when charging
saylor23
PostSubject: Re: Balance lead problems   Thu Sep 13, 2012 7:46 am
I have checked, the items you mentioned, will check again, what are you thoughts on the leads, red and black, what or are there meter's out there to check these type of problems
People Skills : 5887
PostSubject: Re: Balance lead problems   Sun Sep 16, 2012 9:39 pm
What kind of charger are you using?
I Used a thunder power tp610 this past year and had a terrible time with it and a123
It would constantly tell me there was a voltage error and stopped the charge and you couldnt charge without plugging the balance lead in
Ended up using cheap Chinese knock off chargers and they worked great!
saylor23
PostSubject: Re: Balance lead problems   Mon Sep 17, 2012 7:54 am
HiTEC X4- thinking that might be a issue, only have one charger, I can charge and balance a 2 cell pack that I bought, from a shop that made them up, is there a way to tell or test the charger
saylor23
PostSubject: Re: Balance lead problems   Mon Sep 17, 2012 9:37 pm
What Charger do you think is worth getting, spent 150 on this one???
Alex P. HASD Bots
People Skills : 2762
PostSubject: Re: Balance lead problems   Tue Sep 18, 2012 8:11 pm
check and assure that all wire lengths are the same, this could possibly screw you up if they are not
saylor23
PostSubject: Re: Balance lead problems   Wed Sep 19, 2012 7:45 am
checked it, I am starting to think it is my charger
» problems with caseroles
» Problems in translation Google
» Lead weights for wheels - wtb in SG?
» problems on first use
» Solving SRS Light Problems for a D2
