 Balancing One tooth drum
jtmurrer
People Skills : 1913
Registration date : 2013-03-15
PostSubject: Balancing One tooth drum   Fri Mar 15, 2013 12:50 pm
We have designed and built a one tooth drum, it was perfectly balanced on the software but when we got it back from the machinist it is slightly unbalanced. I was just wondering what others have done in the past to balance their asymmetric weapons.
TOP SECRET
People Skills : 3800
PostSubject: Re: Balancing One tooth drum   Sat Mar 16, 2013 1:40 pm
Depends on what you mean by 'slightly.' I probably would just run it and see what happens.
jtmurrer
PostSubject: Re: Balancing One tooth drum   Mon Mar 18, 2013 9:43 am
Its slightly off balanced by when you put it on the table it wants to roll toward the opposite side of the tooth. But when we spin it up it goes to around 8000 rpm were hopin to get more out of it by balalncing it and were wondering what others have done.
jtmurrer
PostSubject: Re: Balancing One tooth drum   Mon Mar 18, 2013 10:43 am
Would they be able to do it if its solid steel? With two small holes towards the tooth.
jtmurrer
PostSubject: Re: Balancing One tooth drum   Mon Mar 18, 2013 8:21 pm
After calling several shops and only finding one who was capable of doing it then telling us he wont because of liability issues we found a way to balance it better. It currently weighs 5lbs at 2in in diameter and spins at 8000k rpm I feel as if the rpm is low, was hoping for more of 16000. Were using the fieago 540xl 1:1 and i feel as if it should be more.
People Skills : 3558
PostSubject: Re: Balancing One tooth drum   Mon Mar 18, 2013 10:56 pm
jtmurrer wrote:
It currently weighs 5lbs at 2in in diameter.
is it a solid steel drum?
jtmurrer
PostSubject: Re: Balancing One tooth drum   Tue Mar 19, 2013 4:53 pm
Yep solid steel one tooth drum, might be a first, just wondering what rpms u think I'd be able to get out of it with that weapon motor
PostSubject: Re: Balancing One tooth drum   Tue Mar 19, 2013 6:48 pm
what is the kv of the motor and the voltage that is going to it
jtmurrer
PostSubject: Re: Balancing One tooth drum   Tue Mar 19, 2013 6:56 pm
It's the fieago 540xl and I believe it's 1490kv off the top of my head and its 13.2 volts thru it so the motor should be 20000? With no load or drag
People Skills : 5982
PostSubject: Re: Balancing One tooth drum   Tue Mar 19, 2013 8:02 pm
Thats alot of drum for that motor especially if your running it 1:1
jtmurrer
PostSubject: Re: Balancing One tooth drum   Tue Mar 19, 2013 8:38 pm
We also have a 1:2 ratio pulley that got the same rpm (8000)
