 Castle ICE 100 problem
saylor23
People Skills : 2622
PostSubject: Castle ICE 100 problem   Sat Mar 16, 2013 3:38 pm
We are running a ice 100 with a castle 2200KV motor, 4 cell A123 pack, when we running weapon motor without the weapon , it runs fine, shut off once, if we run with the load of the weapon (3.5 lb drum) cuts off after starting slowly, am I missinf a voltage shut off, in the castle software?????
zwtipp05
People Skills : 2861
Registration date : 2010-05-21
PostSubject: Re: Castle ICE 100 problem   Sat Mar 16, 2013 4:38 pm
Would setting the voltage cutoff to one of the hard limits (say 9.0V) instead of auto-detect LiPo solve your issue? You could probably even set it lower, but would need to be careful not to discharge your batteries so low that you damage them.
saylor23
PostSubject: Re: Castle ICE 100 problem   Sat Mar 16, 2013 4:59 pm
That is a option, we tried to go with this four cell pack, Bloomsbury uses this same configuration
saylor23
PostSubject: Re: Castle ICE 100 problem   Sat Mar 16, 2013 5:30 pm
Marshall is the one that recommended that setup
saylor23
PostSubject: Re: Castle ICE 100 problem   Sat Mar 16, 2013 7:24 pm
thanks, I try them on monday, and the belt we are using is a little snug, the one we plan to use did not come in yet
» Powderham Castle Crash box Rally
» possible 4l60e problem?
» I need some help with a Nerf problem..
» power transformer problem - help?
» Aha the sought after Len Castle pin dish has turned up on TradeMe :)
