| Thinking of changing Sting from drum to beater??? | |
| Subject: Thinking of changing Sting from drum to beater??? Mon Jul 20, 2009 4:12 pm | |
| I don't know if I can reliably keep the teeth on Sting's drum and make weight, so I am thinking of converting over to a single blade beater.
I forsee future battles against horizontal spinners,etc and am leaning towards the beater setup, in that I can see the alu drum going south or the teeth coming off, once the going gets reaaly rough..which I'm sure it will.
What do you think?
| Subject: Re: Thinking of changing Sting from drum to beater??? Mon Jul 20, 2009 4:38 pm | |
| I would stick with the drum | |
| Subject: Re: Thinking of changing Sting from drum to beater??? Mon Jul 20, 2009 5:10 pm | |
- I would stick with the drum
Might end up with both....lol I thought that you were big into the sns beater thingie???? One big factor is...if weight is equal, which will draw more amps??? I'm using a tiny little castle motor...not meant to beat, just spin to the moon and let things fly. Even with some extreme mods, the motor setup is fragile at best..... | |
People Skills : 6156 Registration date : 2009-03-15 Age : 31 Location : Miami, FL
| Subject: Re: Thinking of changing Sting from drum to beater??? Mon Jul 20, 2009 8:35 pm | |
| eggbeater has more air drag.. so it would take more amperage.. | |
| Subject: Re: Thinking of changing Sting from drum to beater??? Mon Jul 20, 2009 8:53 pm | |
| - will bales wrote:
- eggbeater has more air drag.. so it would take more amperage..
Maybe some aerodynamics ...to bring that down??? From the sound of Sting's and TTATT's drums. they seem to be pushing a lot of air??? | |
Stephen super contributor
People Skills : 5608 Registration date : 2009-11-01 Age : 29 Location : West Mifflin
| Subject: Re: Thinking of changing Sting from drum to beater??? Sun Nov 01, 2009 1:20 am | |
Last edited by hallboy8222 on Sun Nov 01, 2009 1:24 am; edited 1 time in total | |
| Subject: Re: Thinking of changing Sting from drum to beater??? Sun Nov 01, 2009 1:22 am | |
there's less wight with the egg beaterso air resistence shouldn't matter and i like beaters more if u make them right | |
People Skills : 6568 Registration date : 2009-03-14 Age : 35 Location : Miami, FL / Atlanta, GA
| Subject: Re: Thinking of changing Sting from drum to beater??? Sun Nov 01, 2009 1:43 am | |
| - hallboy8222 wrote:
there's less wight with the egg beaterso air resistence shouldn't matter and i like beaters more if u make them right Well, the thing is these aren't normal speeds for a beater (40,000+ RPMs). Some fiddling will probably be required to make it work well at those speeds. | |
People Skills : 5786 Registration date : 2009-04-30 Age : 33 Location : Bradenville, PA
| Subject: Re: Thinking of changing Sting from drum to beater??? Sun Nov 01, 2009 1:59 am | |
| Eggbeaters are "meh" on aerodynamics. If you can fillet/round off and non contact edges, you improve the airflow greatly. Those sharp corners are just perfect for creating bad turbulence. Albeit a very small one, but the faster you go the more fierce it gets.
At lower speeds of around 5-8k rpm its negligible, but once you hit 15k and up you are asking for very bad gyro, and extra amp draw. Its not much, but at those speeds it can grow exponentially. | |
| Subject: Re: Thinking of changing Sting from drum to beater??? Sun Nov 01, 2009 2:14 am | |
| A thought: would winglets or winglet-like extrusions work on a beater? | |
| Subject: Re: Thinking of changing Sting from drum to beater??? Sun Nov 01, 2009 2:18 am | |
| Where would this said "winglets" go?
Care to make a crude paint drawing? | |
| Subject: Re: Thinking of changing Sting from drum to beater??? | |
