 Anti Hyzer V.2 antweight fbs
+4
Koensig
Evan Steeves
8 posters
Go to page : 1, 2  Next
Evan Steeves
People Skills : 5322
Anti Hyzer V.2 antweight fbs Empty
PostSubject: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeSat May 07, 2011 11:41 am
Version two of my catbowl spinner...
Things that needed improvement:
1. center of gravity, the first version was over 2.2 inches tall and only 4.75" wide so it was very high
speed stable but low speed understable, thats how it got its name too Very Happy
2. chassis, it had so much flex because i used one single piece of carbon fiber as the entire frame
3. shell, it was a great shell but it deformed under hard hits around the teeth because it was stainless
4. drive, the first version used sanyo micro gearmotors this version will use spark gold 20:1s
5. weapon motor, previously i used a park 400 with an s7 drillshaft it worked perfectly but lacked the
oomph i was looking for in hits it would have enough torque to self right but only topped out at 6300rpm
using an airplane tach and electrical tape for index
soooo heres the new stuff
Full hexel texalium frame i love this stuff lots more flex then carbon but twice the shock load capability
using carbon fiber angle for corners and baseplate mounting using m3's
spark 20:1's using custom bonded minisumo wheels that fit over the gearbox and polulu motor mounts
with a 1/4" block of delrin used as motor clamps.
Anti Hyzer V.2 antweight fbs Antweight1.th
also the motor layout allows me to actually drive this robot unlike my last wheel layout that left me with about as much control as a melty
and my favorite part.
Anti Hyzer V.2 antweight fbs Antweight2.th
The new weapon motor park 480 low kv version with a 7075 aluminum hub that
bolts into the motor on 2 axis and will allow my overall height of the robot minus the hub to be .75" tall
and the rough layout
Anti Hyzer V.2 antweight fbs Antweight3.th
input is always welcome
People Skills : 6131
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeSat May 07, 2011 1:04 pm
nice, i like the wheels. and the weapon hub, should help save the motor some
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeSat May 07, 2011 1:08 pm
i just started turning down some s7 rod for a 4mm motor shaft. i think if its going to break it will crush the motor can now Very Happy
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeTue May 17, 2011 8:30 pm
Alright so the robot is complete. the shell is balanced to about 1/10th a gram using lead tire tape(about .4gram) and a magnetic balencer for airplane props so hopefully i dont screw it up putting the teeth on
as it is right now without teeth it sits at 14oz cheers
some pics...
its alot roomier than my last antweight so I was able to heatshrink, shoegoo, and cable tie everything down and secure.
Anti Hyzer V.2 antweight fbs Ant5n
sitting at just a hair over an inch tall with 1/16" ground clearence on the shell and 1/8th on the robot its looking fancy
Anti Hyzer V.2 antweight fbs Ant6r
Using a piece of black tape for index I was able to tach it at just above 6500 rpm top speed. With a full charge I was able to get a solid 7 minutes of full speed weapon with driving so under combat load on the weapon motor it should last a full 3 minutes.
and I like to list my stuff for others so here...
1. .059 carbon fiber about an 8"x8" sheet
2. 3" of carbon fiber angle with 3mm thickness
3. 32 m3 buttonheads and 22 aluminum m3 locknuts
4. polulu sanyo motor mounts 4x, 1/4" delrin blocks under for spacers
5. fingertech spark gold 20:1 x2
6. custom wheels with 20a durometer tread
7. fingertech tiny esc x2
8. robot marketplace v tail mixer
9. dys 30 amp esc
10. park 480 910kv weapon motor
11. thunderpower 325mah 45c 2 cell lipo
12. 1 foot of deans 16g wire
13. 5 servo male leads for shortened signal wires
14. 7075 aluminum rod 2.25"x2" for hub
15. titanium shell from japan
16. shoegoo for shock mounting reciever and v tail mixer
17. couple zip ties and deans plugs Laughing
anyone with any ideas on a micro switch pleasseeeeee let me know!!!!!!!
People Skills : 8015
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeTue May 17, 2011 8:42 pm
Looks really sweet!
Try nor to modify that roll ring on the bottom when putting on your teeth, thats where all your ring strength is
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeTue May 17, 2011 8:58 pm
youre right cody, I ended up with an oval shaped shell on my first ant because I cut the ring. This time im going to use about 6-12 m3's to hold each tooth in place with washers on the back to spread the load out.
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeTue May 17, 2011 10:23 pm
nice call alex they are fingertech sumo wheels!
and what do you use for switches on your insects?
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeTue May 17, 2011 10:36 pm
top secret how I aquired the wheels, I get the not-so-much discount Rolling Eyes but do micro deans really work I have a bunch laying around and I never use them because the contacts are freaking tiny and would seem to bottleneck the amps ? maby im way off lol
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeTue May 17, 2011 11:09 pm
tomorow ill do some destructive testing to see when they fail if it holds together without melting at a 50 amp shock load to simulate a 250 watt motor going from full speed to dead stop like a weapon motor does I think it will be a winner.
someone should make a mini whyachi style screw switch for insects, I would buy a bunch Very Happy
Koensig
People Skills : 5107
Registration date : 2011-02-25
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeThu May 19, 2011 8:50 am
I agree with that. The current Whyachis are too big and expensive for anything under hobbyweight.
spazzikarp
People Skills : 4929
Registration date : 2011-05-20
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 20, 2011 2:23 am
I keep tellin' you. Micro Dean's will be fine. I've pushed more current than you will through a JEST connector. If you get for realizies Micro's, it'll be more than fine. It would save soooo much space...
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 20, 2011 9:39 pm
okay seth ill try it, im still afraid of how tiny they are but I supose it will help with making a removable link.
People Skills : 6570
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeSat May 21, 2011 10:19 am
I vote JST too. I've never had a problem with it.
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeThu May 26, 2011 10:43 pm
so I put teeth on in the form of 1/4" grade 8 bolts on the shell today and started hitting some stuff and although it is very very powerfull and spins to the moon I know its going to destroy my shell in less than one fight Sad
so after gcrs and I self destruct its going to be back to the drawing board to do things the right way with a titanium shell of real thickness.
at least im having fun learning along the way... Very Happy
Camden W
People Skills : 5123
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 27, 2011 12:31 am
if only i was to the same point as you on your fbs... Rolling Eyes hopefully i won't run into self-destruction on my first few tests.
can you post some pics of it with the teeth on? Shocked
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 27, 2011 1:04 am
shure heres the top view... 3, 1/2 oz 1/4" grade 8 bolts with 1/4" washers
Anti Hyzer V.2 antweight fbs Ant7
side view on the robot: about 1/4" ground clearance of the teeth... not at all how I wanted it but hey its temporary... until I design a third revision to this full body spinner puzzle. it seems like I either go too little weapon motor or too much next version will be a nice blend of the two Rolling Eyes
Anti Hyzer V.2 antweight fbs Ant8
for actual combat after my first match when I destroy this shell Im working on bending a spring steel edger blade to use as an overhead bar spinner, to at least pose some threat to something besides itself. Laughing
Camden W
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 27, 2011 1:29 am
how fast is the spinup? and can you rough estimate its RPM? (KV of the motor and voltage applied)
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 27, 2011 1:38 am
using electrical tape for light index and an rc airplane tachometer I clocked it at a healthy 6300 rpm +-100 with the tape index variable. so it spins scary fast and spin up time is how smooth I use my throttle. it will go to full power instantly if I give it full instant throttle it will go up on edge and jump around and blow white sparks at least 5 feet away Laughing
the kv of the motor is 910 its designed to swing a 12x6 airplane prop so my little ant shell really dosent phase it my battery is a 2 cell thunderpower 45c 350mah after a full battery the motor is cool and the battery is warm.
Camden W
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 27, 2011 1:42 am
If that's scary fast, then my estimate of 10k rpm on my fbs might be even more so Shocked I hope to have spinup be about 2-3 seconds, under control that is tongue you should test it out on cardboard to see what happens Laughing
also, how long does it last on a full charge under battle condition loads?
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 27, 2011 1:53 am
it will blow through cardboard like its not there lol
it puts nasty gashes in my hardwood test floor walls.
and 10k is pretty high i would worry about the shell stretching and wanting to coin itself at that speed some objects arent ment to spin that fast when you start to get into that high of rpm you have to add things like rings to keep stuff from streching because at that speed the shell is trying to blow itself up.
for example my shell with the teeth on at 3/4 throttle or around 4 thousand rpm will start to develope a harmonic due to the geometry and material properties and wind resistance and stability of its construction when i break through this harmonic the shell starts to grow and at full throttle i would say it streches a full 1/16" on either side or 1/8" total so if i went to 10k i would anticipate it would start to split if it didnt have a band around it to retain it at high rpm
Camden W
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 27, 2011 2:01 am
sounds like it can handle a multitude of fights without problems Wink if possible, could you even post a video of it? that would be really cool to see it hit stuff and hear the harmonics you're talking about bounce and sorry if i'm being excessively nosy... Embarassed
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 27, 2011 2:08 am
tomorow ill have some video up of it hitting some full spraypaint cans as tradition of my last antweight( kind of a destructive method of a paintjob) Laughing
and thanks for the optimism and no your not beying nosy at all.
but the shell is seriously like 28guage titanium its soft enough that I anticipate either rolling a tooth over or pulling one through the shell on a solid hit at high rpm. if i play conservative and dont go full throttle it might stay intact but thats no fun im looking for sparks and a big hit cheers
Camden W
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeFri May 27, 2011 9:46 pm
where's those videos? Suspect
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeSat May 28, 2011 12:48 am
I took them so he doesn't have them. Razz
but I don't have them either cause i left the camera at work... haha
(but don't tell evan i told you this, but it was kind of disappointing...)
tongue
Evan Steeves
PostSubject: Re: Anti Hyzer V.2 antweight fbs   Anti Hyzer V.2 antweight fbs I_icon_minitimeSat May 28, 2011 10:07 am
tongue
yea it was a total fail i tried to hit the spray paint can and drove into a pile of sand and locked up both fingertech spark gold motors so after a cleaning and lubricating its back and ready to try not to fail again, its really hard to drive because i have no idea witch way is forward until i put lights on Rolling Eyes
Page 1 of 2Go to page : 1, 2  Next
» vetala antweight bar spinner.
» New Antweight
» Wiring an antweight
» antweight drive
» Jukid-Antweight
Battlebots :: Team Update Pages :: Evan Steeves' Robot Projects-
