RavenFire
People Skills : 3543 Registration date : 2014-08-18
| Subject: Batteries for 15 Pounder Mon Aug 18, 2014 5:24 pm | |
| Hi guys. I'm looking for any advice anyone has on good batteries for the 15 pound class that aren't LiPo. Any help or suggestions are much appreciated. Thanks in advance. | |
People Skills : 4920 Registration date : 2011-04-10 Age : 29 Location : Blaine Minnesota
| Subject: Re: Batteries for 15 Pounder Sat Aug 23, 2014 10:16 am | |
| a123 li-ion cells or similar are what many people use. | |
RavenFire
| Subject: Re: Batteries for 15 Pounder Sat Aug 23, 2014 8:19 pm | |
| Is there a specific supplier that sells them? | |
| Subject: Re: Batteries for 15 Pounder Sun Aug 24, 2014 6:28 pm | |
| - RavenFire wrote:
- Is there a specific supplier that sells them?
I've used hobbyking's ( these were a disappointment do not order from hk)and ep buddies cells and they seemed to work ok.....there is also buya123s.com where they are supposed to sell straight from the manufacturer.
Last edited by Don Doerfler on Sun Jan 25, 2015 6:06 am; edited 1 time in total | |
saylor23
People Skills : 4877 Registration date : 2011-04-15 Age : 57 Location : Windber,PA
| Subject: Re: Batteries for 15 Pounder Sat Jan 24, 2015 8:54 am | |
| We are looking at the Ryodi battery, 4Ah, dose anyone know if you can just take the batteries out of the plastic case??? or do I need to disconnect something??? 75 for two 18v packs, if it works it's a cheap fix. I know one team that use Drill packs with no problems. any thoughts??? | |
| Subject: Re: Batteries for 15 Pounder Sat Jan 24, 2015 4:05 pm | |
| - saylor23 wrote:
- We are looking at the Ryodi battery, 4Ah, dose anyone know if you can just take the batteries out of the plastic case??? or do I need to disconnect something??? 75 for two 18v packs, if it works it's a cheap fix. I know one team that use Drill packs with no problems. any thoughts???
Clariton uses the craftsman packs ....im currently experimenting with the dewalt 3s 12v 2000mah lithium ion packs in a mantisweight and i was able to remove the cells with no issue and reused the plastic casing as an adapter for charging | |
| Subject: Re: Batteries for 15 Pounder | |
