Current Robots-Near Chaos Robotics (East) 5 5 3
Goto page : 1, 2, 3 ... 10 ... 20  Next
MikeNCR
People Skills: 1421
Registration date: 2009-04-27
PostSubject: Current Robots-Near Chaos Robotics (East)   Thu Jun 04, 2009 4:36 pm
Mr. Self Destruct
30lb
2wd via 18v dewalt motors
s28-150 Magmotor powered bar (28x3x3/8")
Status: Electrical system is being worked on. Waiting on new "Firecracker" speed controller and Wills new power switch to complete. Debut will likely be Franklin Institute or the yet to be named North Carolina competition in the winter.
Interstellar Overdrive/Apollyon
15lb/12lb
2wd via Mini-EV motors
Wedge & Steel claws
Status: Being redesigned. Old chassis and gearboxes have been scrapped. New Mini-EV gearbox is being designed. Redesign intent is to lighten the main chassis while improving drive system reliability. This will allow for interchangeable front manipulators. Cad drawings will be posted once I've done them. Also looking into the P60 gearbox as a potential replacement gearbox.
http://nearchaos.net
People Skills: 1890
Registration date: 2009-03-15
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Thu Jun 04, 2009 5:50 pm
I've finished a switch.. but it's really hard to machine some of the contacts. Once I make a second one, I'll start sending them around.
MikeNCR
People Skills: 1421
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Thu Jun 04, 2009 5:53 pm
Sounds good, with the way I do the electronics, I'll need two switches (Isolated weapon and drive power), so just let me know when you're taking orders and how much.
People Skills: 1890
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Thu Jun 04, 2009 6:05 pm
got it! when would you need them by?
MikeNCR
People Skills: 1421
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Thu Jun 04, 2009 6:20 pm
Any time in the next month would be fine. Still waiting for Robot Power to release the Firecracker
( http://www.robotpower.com/products/firecracker/ )
People Skills: 1890
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Thu Jun 04, 2009 7:08 pm
okay.. and you need 2?
MikeNCR
People Skills: 1421
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Thu Jun 04, 2009 7:57 pm
Yes.
MikeNCR
People Skills: 1421
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Fri Jun 05, 2009 12:07 am
Playing with potential design alterations. Here's option 1:
Drive: 550 motors through banebots p60 gearboxes(16:1)
Power: 5 Cell A123 (Yes, I'll have spare motors!)
Special Feature: Interchangeable front attachments
I should clarify that I use Rhino3d as essentially a 3d sketching program for checking ideas and component layouts.
People Skills: 3504
Registration date: 2009-03-31
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Fri Jun 05, 2009 1:24 am
we run bb 550's with fans on them / 5 cell A123's and haven't smoked one yet....16:1 as well....with 3" wheels it's quite fast and pushes very well also
This was on our rattlers
The new Ti bots are using a hotter motor, smaller/wider wheels and a belt reduction....much more torque and same or more top speed. Hard to keep the wheels from spinning tho...
MikeNCR
People Skills: 1421
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Sat Jun 06, 2009 1:29 am
What motors are you using?
On a different note, I'll probably have most of the electrics on Mr. SD done within a week or two.
People Skills: 3504
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Sat Jun 06, 2009 7:41 am
I can't say which ones we'll end up with, but we are looking at tritons, Integys, Venoms and Trinities , depending on the bot..but not any of the really hot winds....
Brush wear on the rebuildables is not great at higher voltages.
Depending on budget anything from a triton on up seems pretty good.
btw: If you or anyone has any suggestions on 540/550 motors to try.....please let me know
Thanks
MikeNCR
People Skills: 1421
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Sun Jun 07, 2009 8:21 pm
I've been informed that there's a new 42mm gearbox (non-banebots) on the way for RS775 motors that'll be on display at RoboGames this year. I'll be giving them a look before committing to a specific gearbox solution.
People Skills: 2028
Registration date: 2009-03-14
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Mon Jun 08, 2009 11:43 am
we tried the banebots 550s and duratrax 550s for dethinator this year. banebots DON'T have RF suppression capacitors in them, while the duratrax do. But the duratrax run hotter (and faster). Idk.. i wouldn't really recommend either. They were both pretty cheap.
People Skills: 3504
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Mon Jun 08, 2009 12:14 pm
If you go, try and get us some info and maybe pics??
Thanks
MikeNCR
People Skills: 1421
PostSubject: Re: Current Robots-Near Chaos Robotics (East)   Mon Jun 08, 2009 5:15 pm
I won't be at RG, but I suspect pics will be online soon.
I'll quote the person who's going to be releasing them:
Quote:
We're importing a new 20:1 42mm gearbox from China. It will come mounted to an RS775 motor so I guess it is really a gearmotor. It has power somewhat less than the Mini-EV. The motor is wound for 14.4V. We should have some to show at RG this year. If you're there you can come and check them out. The pinion looks the same as the GB42 pinion but I haven't actually compared them.
and
Quote:
Our gearbox is pretty heavy steel but it is solid. In testing we mounted a 2' bar to the output shaft, spun up to speed and repeatedly whacked it against a solid surface. The bar bent and the output bearing got kind of gritty sounding but the gears inside were perfect. We also tried repeated stall testing to see if the pinion would spin or the carrier pins would pull out. No problem even with the motor smoking. So we're happy with this gearbox. Hopefully the production units will be just as tough.
Page 1 of 20Goto page : 1, 2, 3 ... 10 ... 20  Next
» At home in the far away, the far away of the East
» Chaos Photon
» Queen's Gate: Spiral Chaos
» List Of Current Mods/Judges
» Current food crisis at the new campus
Battlebots :: Team Update Pages :: Near Chaos Robotics-
