| Current Robots-Near Chaos Robotics (East) | |
+16Camden W Koensig Evan Steeves Don Doerfler jeeves_m_d Stephen crowconor SamM Jeff L Koolaid64 Cody rdubard SenaiERI Dan Curhan rjw Will Bales 20 posters |
MikeNCR super contributor
People Skills : 5844 Registration date : 2009-04-27 Age : 36 Location : Norcross, GA
| Subject: Re: Current Robots-Near Chaos Robotics (East) Tue Jan 10, 2012 10:23 pm | |
| Far more detail than you ever wanted to know about tweaking lite flites to improve performance: http://nearchaos.blogspot.com/2012/01/making-wheels-round.html | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Mon Jan 16, 2012 5:20 pm | |
| Everything for the chassis besides the top armor (which will be determined once the rest is built/weighed) arrived today: | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Wed Jan 18, 2012 6:46 pm | |
| Coming along quickly- | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Thu Jan 19, 2012 10:43 pm | |
| Here's what I got done today-
Weight is 28lbs, 13.4oz with the battery, speed controllers and all the remaining fasteners, leaving 1lb 2.6oz for the top armor, rx and a bit of wire.
| Subject: Re: Current Robots-Near Chaos Robotics (East) Sat Jan 21, 2012 6:05 pm | |
| It LIVES!
https://www.youtube.com/watch?v=vfZ7K4YZudQ | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Wed Feb 01, 2012 10:19 pm | |
| 29lb 14.8oz | |
People Skills : 5649 Registration date : 2009-12-24 Age : 30 Location : Plum,Pa
| Subject: Re: Current Robots-Near Chaos Robotics (East) Thu Feb 02, 2012 9:32 pm | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Fri Feb 03, 2012 12:10 am | |
| Weapon testing:
https://www.youtube.com/watch?v=-hgkGnrr2Zo | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Fri Feb 03, 2012 3:47 pm | |
| Here's the whole fleet for Motorama: | |
People Skills : 4932 Registration date : 2011-04-10 Age : 29 Location : Blaine Minnesota
| Subject: Re: Current Robots-Near Chaos Robotics (East) Fri Feb 03, 2012 5:12 pm | |
| Aww, those little ones are so cute | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Tue Apr 17, 2012 5:17 pm | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Sun May 13, 2012 5:52 pm | |
| Progress on the safety cage for my practice arena. The next two planned ants should have spinning weapons, so walls are somewhat necessary for safe testing. | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Mon May 14, 2012 12:11 am | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Mon May 14, 2012 1:06 am | |
| internal area is 49"x49", meant to just barely fit over the 4ft square combat area. | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Thu May 24, 2012 9:58 pm | |
| Here's Klazo, Julies new antweight- It's a prototype for an upcoming Kitbots kit. | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Thu May 24, 2012 10:03 pm | |
| Not 100% sure. Gearbox size is a near perfect match for the sparks, motor is just a fair bit shorter. Going by the sticker on the motor it's a size 030, so 2s lipo should be fine, 3s is probably a bit too much. | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Thu May 24, 2012 11:09 pm | |
| They look similar to the motors that come in Tetrix (I think that's what it's called) kits... | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Thu May 24, 2012 11:22 pm | |
| Gearbox length is a bit too long, (37mm vs 32.5mm) but it's pretty much the same thing. I don't think they'd fit in the Kitbots kit. The Kitbots ones are also 500rpm instead of 1000rpm, so a bit more torque and less speed. | |
zwtipp05
People Skills : 5122 Registration date : 2010-05-21
| Subject: Re: Current Robots-Near Chaos Robotics (East) Fri May 25, 2012 8:22 am | |
| The Kitbots ones are bigger motors. 3 oz each and about 1" diameter with a 4 mm shaft | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Tue May 29, 2012 10:39 pm | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Wed May 30, 2012 11:16 am | |
| I didn't have a 2s pack handy, so I tossed a 3s 250mAh pack in there. For the Carolina event it'll be running on 2s. The motors seem decent, though it only weighed 208g for the test, so once you add the drum and all the extra parts that'll probably slow it down a decent amount. | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Wed May 30, 2012 2:24 pm | |
| Attempting to have a second new ant for CotB3 as well, this is Algos- 1/16 and 1/32" ti all around, 3/32"x2" hardened 4130 disk somewhere between 10-15krpm. | |
People Skills : 5131 Registration date : 2011-02-05 Age : 33 Location : towson md
| Subject: Re: Current Robots-Near Chaos Robotics (East) Wed May 30, 2012 4:46 pm | |
| I like that tooth design being reversible. Are you going to use some sort of nut strip to hold all of the armor and frame plates together. | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Wed May 30, 2012 5:27 pm | |
| Any reason for the split tooth? | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) Wed May 30, 2012 5:46 pm | |
| Using the kitbots 3/16" nutstrip to hold it all together.
The split tooth is purely aesthetic. The overall shape of the disk is somewhat skull-like, so I figured I'd give it teeth. | |
| Subject: Re: Current Robots-Near Chaos Robotics (East) | |
