| Help pick a beater for Sting | |
People Skills : 7771 Registration date : 2009-03-31 Location : Miami
| Subject: Help pick a beater for Sting Fri Jul 31, 2009 7:18 pm | |
| Here are a coupls of ideas for Sting's beater (3 lbs. bot) Both are single tooth designs, 1 is conventional and the other is with staggered blades...both are balanced in solidworks All opinions or other ideas are welcome...remembering that weight is a BIG factor... single blade beater..... staggered blades....wierd stufff....keeping in line with my other wierd stuff | |
People Skills : 7818 Registration date : 2009-03-16
| Subject: Re: Help pick a beater for Sting Fri Jul 31, 2009 9:59 pm | |
| maybe filleting/contouring the non-toothed edge so its less resistent to bite | |
| Subject: Re: Help pick a beater for Sting Fri Jul 31, 2009 10:10 pm | |
- maybe filleting/contouring the non-toothed edge so its less resistent to bite
which one are you referring to....or both?? On beater 1, the toothed edge is over 1/4" longer than the back edge, so I doubt that the back edge would ever hit anything, but some contouring would possibly help reduce drag. The view of beater 2 is misleading...the cutting edges are parallel to each other and to the mainshaft, so again, the angled or back edges would probably not see much if any action. | |
| Subject: Re: Help pick a beater for Sting Fri Jul 31, 2009 11:07 pm | |
| i didnt pay attention to the tooth front and back lol so disregard to directional arrows hahaha The red edges with the arrows pointing to them Even with the round edge im sure itll still bite here and there | |
| Subject: Re: Help pick a beater for Sting Sat Aug 01, 2009 12:33 am | |
| It will be interesting to see if it ever will bite in those places, escept for at maybe 10 rpm or something really slow Not saying that you are right or wrong, but....think about this.... Let's say that the difference in distance between cutting and trailing edges is 1/4"...how fast would the bots have to be moving towards each other (combined drive speed) to get better than a 1/4" bite??? If I make beater 1, a re'balance would have to be calculated to accomodate any changes If I make beater 2, as long as they are equal, I can do just about anything to the trailing edges....which would also help lose some weight (agood thing in this case) and maybe help with some aero as well Thanks for the feedback.... | |
| Subject: Re: Help pick a beater for Sting Sat Aug 01, 2009 12:37 am | |
| Most beaters get great bit with squared edges like that, just figureing you would rather bite with the tooth then other parts but i thing i like the second one better, very different and awesome if it would work | |
| Subject: Re: Help pick a beater for Sting Sat Aug 01, 2009 1:02 am | |
| As I said, if anything gets that close....as in more than 1/4" inside the radius of the cutting edge, then I guess at that point, either the beater is not spinning anymore, or if it is, then I'd like to hit them with anything available...hahaha.....cause I'd be in BIG trouble already. the 2 cutting edges meet in the middle, with no overlap, so alignment between 2 bots would have to be perfect to get a double hit....I might change it to give just a hair of overlap on a second one, if the first works out what do you think?? the drum has a bit of overlap and the occasional double hit does some pretty serious biting... Here's the front view of beater 2 | |
| Subject: Re: Help pick a beater for Sting Sat Aug 01, 2009 2:15 am | |
| Here's the cody beater...hahaha.... Looks like high tech bs...maybe it belongs in the tech toys thread...if it works Hardly looks like a beater anymore...maybe nobody will notice...lol | |
| Subject: Re: Help pick a beater for Sting Sat Aug 01, 2009 11:44 am | |
| looks weird haha idk if youd have to do the inside edges im sure it would save a little weight | |
| Subject: Re: Help pick a beater for Sting Sat Aug 01, 2009 11:52 am | |
- looks weird haha
idk if youd have to do the inside edges im sure it would save a little weight When I get the sizes finalized, I'll cut and test 1 with NO fillets and if it works out (balance wise), I'll cut another with the fillets I think that round edges everywhere possible might help airflow and maybe drop motor amperage a bit. Not a true aerodynamic shape, but it has to be better than square edges and as you noted, it'll save a little bit of weight. On a side note, I might change things so that there is no thru shaft...I have a few ideas on this Wasn't there someone, with a bot named Redemption, I believe, that was hanging shafts on the end of a beater or drum and then into bearings in the outer sides??? Any pics of that...I'm curious and how did that work out as far as rigidity? | |
| Subject: Re: Help pick a beater for Sting Mon Aug 03, 2009 4:29 am | |
| Here's my first attempt | |
| Subject: Re: Help pick a beater for Sting Mon Aug 03, 2009 1:10 pm | |
| Subject: Re: Help pick a beater for Sting Mon Aug 03, 2009 2:11 pm | |
| I'm modifying it to lose a bit more weight....AGAIN !! Another problem is that with a drum, I can put the belt anywhere and keep the drum closer to the width of the bot... this beater is way shorter, which presents several other problems Mostly, that I may have to change a bunch of stuff, or end up with an inch or so of unprotected frontal area, cause unless I make a 2 piece beater, the pulley has to hang off the side, while the motor pulley has to be within the front to back inner braces......baaaaaaahhhhh........ Honestly, I never intended to to put a beater on this bot....but things change...lol So, I might have to spin at well over 40k to get BIG joules......and I don;t know if the wiltle motor will spin a beater that fast, but we'll see | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 1:03 am | |
| Well...it looks like I may go to a 2 piece beater after all.... I have a pretty cool design in the works, and things should work out better overall..... | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 1:19 pm | |
| what do you mean 2 piece? | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 1:41 pm | |
- what do you mean 2 piece?
How about this?? Being that each blade is also balanced, it could be assembled as a one blade or staggered blade beater...shown is the staggered version | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 2:14 pm | |
| is the outside of the none toothed side the same circumference as the tooth? | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 2:20 pm | |
- is the outside of the none toothed side the same circumference as the tooth?
Only at the very tip, then it obviously angles away...it could be changed easily, but I'm thinking that in a straight head on blade to blade, nibbling or grinding as well as defending the belt/pulley might not be a really bad idea?? Otherwise, the odds of getting a perfectly straight hit are probably not that great What do you think? ...knock 1/4" off? or just straighten out the back edge and leave it offset by 1/4" or more?? btw: are we the only ones left on this forum... | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 3:13 pm | |
| So reconsider the numbers i say since ive never done anything this size but what if you did like 1/16" bigger then to pulley on the none tooth side straight across and 1/4" bigger on the toothed side. If you would stagger the teeth you are back to what you had mentioned to me before about the bite. With it spinning as fast as it does im sure one of the teeth would hit it before anything does damage to the belt | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 3:14 pm | |
| shoot i forgot shaft holes through the beater hahaha
Last edited by Cody Harris on Tue Aug 04, 2009 3:31 pm; edited 1 time in total | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 3:19 pm | |
| The main reason for leaving as much weight as possible further away from the shaft centerline, is for balancing/weight purposes. If I offset as much as in your drawing, the counterweights would have to be much heavier...and weight is a big issue for me on this one... does that make sense? btw: that for staying with me on this... | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 3:32 pm | |
| i get exactly what your saying, butttt i thought you could play with that haha | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 3:34 pm | |
- i get exactly what your saying, butttt i thought you could play with that haha
I have, but closr to centerline = MORE weight...otherwise, I would just leave it more symetrical and save some headaches.. | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 3:40 pm | |
| Whats the reason for throwing out the other one if you dont mind me asking? | |
| Subject: Re: Help pick a beater for Sting Tue Aug 04, 2009 3:48 pm | |
- Whats the reason for throwing out the other one if you dont mind me asking?
I thought that i explained that, but I'll try again 1) I would have to hang the pulley off the side, so the beater would be off center 2) I have to keep the motor pulley inside the inner side frame, or it will hit the wheels, so the beater would have to be shorter and even more off center. 3) If i do it that way, then there is a lot of area on either side of the beater( one side a lot more than the other) that is left unprotected, (chewy aluminum), so I would have to re-think and probably redo the outer sides/frontal area, which = more weight that I don't have. so, by splitting the beater, I can slap the pulley down the middle, keep the drive motor/pulley all within the inner sides, and the beater assembly will be a drop in replacement for the drum that was there...pretty much....I think..I hope..I dunno.. | |
| Subject: Re: Help pick a beater for Sting | |
