 Electric Crusher
People Skills: 2314
Registration date: 2009-03-14
PostSubject: Electric Crusher   Tue Mar 24, 2009 4:12 pm
Jeff L wrote:
Electric Crusher
This isn't the most common weapon type in combat robot circles, but it has an excellent track record. Usually driven by hydraulics or pneumatics, smaller versions are possible using electric motors. One variant I came up with a while ago used some of the lessons learned from X-Contamination to build a crusher arm. The intended drive system was one to four high-rpm motors, geared down to sixty RPM as a maximum, driving the linkage system of the crusher arm. The arm itself would be made of either titanium or hardened steel. As an optional add-on, either a carbide tip or a Ferrium C69 tip could be designed into the crusher's point.
This is an extremely feasible design, just not commonly built. In fact, I think a hobbyweight crusher was entered in Motorama a few years ago.
Jeff L wrote:
I'm working on some drawings for this in my spare time as well. More to come.
People Skills: 2314
PostSubject: Re: Electric Crusher   Tue Mar 24, 2009 4:40 pm
Wow, I didn't think I'd come up with something this quickly, but I've got a preliminary design that will definitely work. Scans Pending...
People Skills: 2314
PostSubject: Re: Electric Crusher   Tue Mar 24, 2009 5:07 pm
The Sketches:
Any thoughts? (Other than "Wow, this is really easy to build"?)
People Skills: 1890
Registration date: 2009-03-15
PostSubject: Re: Electric Crusher   Tue Mar 24, 2009 11:16 pm
ya, that's basically what I came up with the first time.. you could use a ball screw to make it more efficient and powerful.
Sean Rubin
Prezerdent of Sexxi Cuddlemen
People Skills: 1612
Registration date: 2009-03-16
Isn't that an exact copy of Razer?
People Skills: 1890
PostSubject: Re: Electric Crusher   Tue Mar 24, 2009 11:17 pm
the big problem is speed. you want to have a dual action type weapon so that you can quickly grab them to keep your opponent from moving, an then the powerful gearbox to crush..
People Skills: 1890
PostSubject: Re: Electric Crusher   Tue Mar 24, 2009 11:20 pm
lastly, the rail idea wont work because it will bind up. it only works for the 1/8th inch of movement where the threaded block is in line with the motor axle. If you put the block on bearings in slots in the arm itself, then you could have it pivot and slide so that the block and the axle are always in line with each other, eliminating any binding.
People Skills: 1890
PostSubject: Re: Electric Crusher   Tue Mar 24, 2009 11:22 pm
if you did the above, you could keep the slots in the robot side plates..
just my 2 cents!
People Skills: 2314
PostSubject: Re: Electric Crusher   Tue Mar 24, 2009 11:49 pm
The problem there is you start trading speed for overall power in the end... that, and the extra space & weight taken up by the competing mechanism would be a bit of a bitch to deal with.
The profile of the crusher arm is, yes. I just put that in as a stand-in; I was more worried about getting the mechanism to drive the arm done than picking a unique shape. Besides, it's seemed to work pretty well for Razer.
Yeah, I noticed that as well. I've decided I'll tackle that problem later; after all, this is just a preliminary sketch.
People Skills: 2314
PostSubject: Re: Electric Crusher   Wed Mar 25, 2009 12:00 am
Also, Razer uses hydraulics.
Electric Crusher
» Electric quiz
» 3 point hitch diagram (electric)
» VAGINA BULU GETAR SILICON ELECTRIC#BIKIN PUAS PRIA DEWASA#
Battlebots :: Bots :: Design-
