Here's some photos from the past few days
After a good cleaning...
Crazy spring steel blade swaybar with integrated droop screws.
I dug out some scrap polycarb from the bin and tapped three m3 screws 10mm deep the mount is half inch thick and mounts 5 of the 6 holes on the motors face.
Three m3 holes drilled and tapped in the 5mm thick 7075 chassis hold the motor
I bolted two axial ax10 slipper hubs together and face mounted a kimbrough rc10gt 32 pitch spur gear. I slotted one of the axial hubs to capture a 8x2mm pin cut from drill rod, the hubs were drilled out to 6mm to fit the larger serpent primary shaft.
heres a top view of the assembly
And a front view of both 32 pitch gears meshing nicely with no motor mount adjustment
Heres the rough electronics layout with nothing bolted down just playing some component tetris for now.
