| Subject: S7 question Wed Apr 20, 2011 3:13 pm | |
| should i get grounded ,dcf ,or hot rolled S7 for my weapon | |
People Skills : 5928 Registration date : 2009-07-05 Age : 33 Location : PA
| Subject: Re: S7 question Wed Apr 20, 2011 3:54 pm | |
| that all depends on how much you want to pay for it and how much work you want to put into it
Luke
People Skills : 4824 Registration date : 2011-04-16 Location : Plum
| Subject: Re: S7 question Tue May 08, 2012 9:41 pm | |
| - Don Doerfler wrote:
- should i get grounded ,dcf ,or hot rolled S7 for my weapon
Tad late of a reply but Dcf means that the decarbed portion has been removed, Hot rolled means that the metal will come with a black scaly finish and a layer of decarb due to the hot rolling process. Grounded means that the tool steel has been ground down to the proper thickness. | |
| Subject: Re: S7 question Wed May 09, 2012 5:46 pm | |
| So you're saying that you can get either decarb or hot roll, and either one can be ground? More work in hot roll and unground, cuz you gotta mill all dimensions to size and then descale after hardening? Just wanna make sure I understand. | |
Luke
| Subject: Re: S7 question Wed May 09, 2012 7:05 pm | |
- So you're saying that you can get either decarb or hot roll, and either one can be ground? More work in hot roll and unground, cuz you gotta mill all dimensions to size and then descale after hardening?
Just wanna make sure I understand. yep as far as I believe , and ones without the decarbed portion removed will not harden as well. | |
