 Shaft for Drum
+3
Alex P. HASD Bots
YostAdvisor
saylor23
7 posters
saylor23
People Skills : 4877
Shaft for Drum Empty
PostSubject: Shaft for Drum   Shaft for Drum I_icon_minitimeFri Feb 17, 2012 6:44 am
What do most people use forr a weapon shaft? 15lb bot, weapon around 3.5lbs. Is 1/2 in rod Titanium enough?
YostAdvisor
People Skills : 4610
Registration date : 2011-10-12
PostSubject: Re: Shaft for Drum   Shaft for Drum I_icon_minitimeFri Feb 17, 2012 12:20 pm
My students and I have discussed the use of titanium shafts over the last two years. We bent two .5" unhardened titanium shaft two years ago and have since switched to A2 Tool steel hardened to 45 rockwell which seems to work great.
Alex P. HASD Bots
Alex P. HASD Bots
People Skills : 5011
PostSubject: Re: Shaft for Drum   Shaft for Drum I_icon_minitimeMon Feb 27, 2012 3:14 pm
we use .5" titanium grade 5 shaft and as long it is supported well we have had no trouble.
People Skills : 5928
PostSubject: Re: Shaft for Drum   Shaft for Drum I_icon_minitimeTue Feb 28, 2012 7:17 pm
its all about how you support it. you really want to have the bearings as close to the frame as possible because where ever your weapon ends is where the most force is going to be applied. if the distance from you weapon to your frame support is less then the diameter then it becomes a matter of shear force rather then yield strength.
-Kyle
People Skills : 5714
PostSubject: Re: Shaft for Drum   Shaft for Drum I_icon_minitimeFri Mar 09, 2012 6:55 pm
Why pay for titanium or S7 when you can get a hardened shaft from McMaster for Less than 20 Bucks. You can order a case hardened shaft at the exact Length you need. 1/2 inch is plenty.
People Skills : 7765
PostSubject: Re: Shaft for Drum   Shaft for Drum I_icon_minitimeMon Mar 12, 2012 4:54 am
Case hardened shafts are soft....(under the case ) you really want a shaft that is hard all the way thru
jtm94
jtm94
People Skills : 5379
PostSubject: Re: Shaft for Drum   Shaft for Drum I_icon_minitimeMon Mar 12, 2012 11:23 pm
Pfttt, case hardened is enough. People get away with much less.
Shaft for Drum
» To Drum or Not to Drum that is the question!
» Mounting pulley to 1/8 shaft
» keyed shaft conductor
» Feigao Shaft snapping issue
» Mounting Spinning Blade to 1/8" shaft
