 bar exam rebuild
+3
Stephen
7 posters
Go to page : Previous  1, 2, 3
People Skills : 6131
bar exam rebuild  - Page 3 Empty
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeThu Nov 04, 2010 11:56 pm
i def like the look of the thicker bars and i would taper both sides so it can be spun both directions in case one side gets worn out or if you have a two way speed controller
Stephen
Stephen
People Skills : 5818
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeFri Nov 05, 2010 12:02 am
Idk we never really had any problems with wearing a drum teeth down but we never really had to many big hits with bar exam any way
Oh and I hate spinning a drum both directions we had a motor doing that last year and I didn't like it
U had to get the stick in the middle to stop it and I would usually over shoot it and spin it the wrong direction
I like it when down is off
People Skills : 5840
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeFri Nov 05, 2010 6:27 am
you could always flip it around it would work even if the teeth arnt tapered if one side wears out
Stephen
Stephen
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeFri Nov 05, 2010 10:47 am
yah if it comes to that we could do that
People Skills : 7968
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeSat Nov 06, 2010 1:06 pm
I would make the teeth THICK, with BIG radii between the teeth and drum, and spin it in both directions
mlecs drum teeth are all in the 3/4" to 1" wide range.
Reverse operation allows you to test your opponents rigidity, assuming that yours is better, you can break their weapon , motor or other stuff, by spinning nthe wrong way....not for the faint of heart
jmho
Stephen
Stephen
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeSat Nov 06, 2010 2:06 pm
jmho
what u mean with BIG radii between the teeth and drum
the teeth are 1/2 already but i could make it better
and making it spin both directions do you need to have 2 slants on the teeth
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeSat Nov 06, 2010 3:48 pm
where the tooth meets the drum body......there should be a large radius.
Angled, slanted, etc = possibly beter bite, but more prone to chipping. blunt = less bit, but more sturdy and will last longer.....don't be swayed by any of my wierd looking teeth designs, keep it simple
People Skills : 8015
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeSat Nov 06, 2010 7:23 pm
how are you plannin on making this?
Are you having the teeth welded?
Stephen
Stephen
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeSat Nov 06, 2010 8:37 pm
its going to be solid s7
were sending a block of s7 to a machining place .... we would do it our selfs but we cant mill s7
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeSun Nov 07, 2010 1:46 am
hmmm....
People Skills : 6135
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeSun Nov 07, 2010 7:55 am
hallboy8222 wrote:
but we cant mill s7
Maybe I'm ignorant, due to my good fortune of having a decent mill, but it seems to me that milling s7 is about the same as milling Aluminum, you just have to
1. use a lubricant (mist systems run as low as $100)
2. Use a carbide endmill (4 flute is good, they might run as high as $20 bucks each)
2. feed the table a lot slower
3. the spindle speed has to be much slower too.
Speeds and feeds are pretty interesting to me--I put together and printed out several excel spreadsheets to guide us in selecting table feeds and spindle speeds with different size endmills on different materials. The only problems I've had since then are ones where I do something stupid (like spin the spindle the wrong way, try to mill material that isn't clamped well, or forget to re-zero the depth!) Recently I've done Titanium and Stainless with good results.
On the other hand, we don't have a 4th axis (rotating table) so we cant do a drum either.
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeSun Nov 07, 2010 8:10 am
Oh, and VERY important--do NOT touch the chips. Aluminum chips are pretty safe, but chips of steel can cut you, or get embedded your skin. Use a shop vac to clean up.
People Skills : 5917
PostSubject: Re: bar exam rebuild    bar exam rebuild  - Page 3 I_icon_minitimeSun Nov 07, 2010 8:19 am
We have a manual mill and no carbide teeth.....
Very limited sizes on the endmills also...
We could turn steel and also mill some simple stuff in S7 like finalizing the blades we did last year but nothing too complex...
We are going to do some CNCing to all of our 6061 this year on a smaller machine we use for the F1 contest.
I am looking at Steve's drum design and thinking that we could go tooth width of 5/8 wide on the drum and 3/4 wide out by the teeth....
that might give him some wider attachment and an angle on both sides....
I am also thinking that raking back just one side will be the answer.....
Somewhere around 9K tooth speed on this one and 10K on our other vertical disc.
That is if my calculations are right....
FRISCO
bar exam rebuild
Page 3 of 3Go to page : Previous  1, 2, 3
» Rocco rebuild
» doomsday Rebuild 3
» Fluffy √2 rebuild for September
Battlebots :: Team Update Pages :: West Mifflin High School-
