People Skills : 4414 Registration date : 2012-04-13 Age : 26 Location : Plum
Subject: first idea im sticking with it Fri Aug 02, 2013 10:11 pm
this is probably my first of many questions but here we go. my robot im designing for a 15lb weight class is going to use aluminum as a bottom plate to be a CORE structural element my first question is what should i use for type wise and also a range of thickness i should use like 1/4 inch Please someone help me
zwtipp05
People Skills : 5103 Registration date : 2010-05-21
Subject: Re: first idea im sticking with it Sat Aug 03, 2013 1:44 pm
Generally what you're after in a frame is stiffness. A simple plate isn't terrible good for that. It's also going to be heavy. Aluminum is very stiff. I personally like 6061 Al since its relatively strong and its cheap. 2024 and 7075 are often referred to as "Aerospace Grade" and they are stronger than 6061. I have heard though that the 7075 can be a bit brittle, which isn't a good thing depending on your application. Something that can bend and spring back to shape is going to absorb energy a lot better than something that can't bend as much (and will be more likely to break).
My designs for the smaller (3 lb and below) tend to be top and bottom plates attached to a lightweight plastic (usually polyethylene). The plates serve as armor and add stiffness while the plastic can bend absorb the energy.
Check out the riobotz tutorial and look around to see what has been done successfully in other robots.
Zachary Knight
Subject: Re: first idea im sticking with it Thu Feb 06, 2014 9:21 pm
i really like that kind of idea i will make sure i look into that. maybe something like UHMW as the center frame pieces with the aluminum to provide the stiffness. there will be 1/8 inch titanium all the way around so that may help with the stiffness. but otherwise for the two pieces for the weapon support the rest could be UHMW. That advice really helps. sorry it took so long to reply i havent been on her in a while.
People Skills : 5630 Registration date : 2009-12-24 Age : 29 Location : Plum,Pa
Subject: Re: first idea im sticking with it Fri Feb 07, 2014 9:28 pm
I wouldn't use UHMW for anything that holds a thread ( they will strip). Also, don't use it for the "weapon supports" it will easily deform.
Zachary Knight
Subject: Re: first idea im sticking with it Sun Feb 23, 2014 8:37 pm
yea the idea has more changed to a 1/8inch aluminum piece for the bottom, if the design can have the the weight the weapon support frame will be 1/2 inch
People Skills : 4913 Registration date : 2011-04-10 Age : 29 Location : Blaine Minnesota
Subject: Re: first idea im sticking with it Thu Aug 14, 2014 10:49 pm
I use polycarbonate as the main frame component on my bot, granted it's 1 lb, not 15.
If you have any vertical chassis structure, I would make that be the main structure, and attach thin plates on the bottom and top.
