quoting jeff here:
Kinetic Energy Batteries
Ever since we saw the first video of Warrior SKF, a Team Whyachi robot, we wanted to make our own version. Warrior SKF is a spinner that can harness the stored energy in its spinning ring to activate a flipper, throwing heavyweight robots six feet into the air (or more). The advantages of such a design are obvious: all the power of spinning weapons, with the precise control of spring/pneumatic/electric weapons. Our first attempt was X-Revolution, which used a three pound section off of some part of a jet engine as the spinning shell. It was also to use a flipper, which was a variant of X-Contamination's own flipper. Unfortunately, since we didn't have any good way to lock the flipper into the shell, it didn't work.
More recently, I've put some work into the concept and have something sitting in CAD that I think would work properly. It's a drum enclosed inside the robot, with a shaft that comes into contact with it and is pushed linearly (I'll find some screen shots and put them up here to clarify). The main disadvantages with my design are the potential for the shaft to break (I have no idea whether it would be able to hold up to being struck by the drum), complexity of the whole assembly (it requires a small microcontroller and sensors to properly time its operation), and the assembly's size. Still, I think it has a reasonable chance of working.
