People Skills : 6377 Registration date : 2009-03-14 Age : 32 Location : Sarasota, FL
Subject: Re: 1 lb drum bot! Fri Jun 19, 2009 9:37 am
here's a video of what my wheels are doing.... eesh. it's weirdd.
People Skills : 5967 Registration date : 2009-03-15 Location : Dallas, Tx
Subject: Re: 1 lb drum bot! Sat Jun 20, 2009 12:31 am
Is your speed controller set to coast down to neutral or cut off immediately? I had that problem in san fran but I just lived with it.
SenaiERI
People Skills : 6173 Registration date : 2009-03-15 Age : 31 Location : Miami, FL
Subject: Re: 1 lb drum bot! Sat Jun 20, 2009 11:19 am
well that sucks! I was hoping to see some videos of this thing throwing stuff around!! I won't make it to the competition because I'm in Hershey, PA. (HERSHEY AMUSEMENT PARK) Tell me all about it! TAKE LOTS OF PICTURES!!!!!!!
People Skills : 7775 Registration date : 2009-03-31 Location : Miami
Subject: Re: 1 lb drum bot! Sat Jun 20, 2009 6:22 pm
Dan
If you went to Barf, let us know what happened...
Thanks
People Skills : 7822 Registration date : 2009-03-16
Subject: Re: 1 lb drum bot! Sat Jun 20, 2009 9:04 pm
will i dont really see you as a hershey park kid hahaha
Subject: Re: 1 lb drum bot! Sat Jun 20, 2009 9:37 pm
lol me neither! my little brother wanted to go
Subject: Re: 1 lb drum bot! Sat Jun 20, 2009 9:38 pm
So, how'd the competition go?! pictures??
the drum spins! I mean it REALLY SPINS! damnnn. so i'm getting really excited.
Everything is done except the top armor and securing things with hot glue. I'll post videos tomorrow - i'm too tired tonight lol
i AM running into a weird problem with my thunderbird though.
when it starts, it beeps and kinda jiggles forward/backward if I start up slow. Otherwise it's fine... but then if it's spinning and i start driving, it stops, and i have to unplug the battery and then reconnect it in order for it to work again. any ideas?
Subject: Re: 1 lb drum bot! Thu Jun 25, 2009 1:10 am
The motor is "cogging". It's that weird sound and stage that it gets in when it just doesn't want to run! sensorless brushless motors all have this problem to some degree. As far as the running problem goes: I think you don't have enough current to run both the weapon and the drive at the same time.. oops!
But I'm only guessing
Subject: Re: 1 lb drum bot! Thu Jun 25, 2009 7:44 am
I agree with Will...
Best thing to do is bench test with a higher capacity battery pack and then take it from there
What battery are you running at the moment?
People Skills : 5942 Registration date : 2009-06-10 Age : 59 Location : Ransom Everglades, Miami, FL
Subject: Re: 1 lb drum bot! Thu Jun 25, 2009 9:32 am
The problems at startup sure sound like cogging--Fluffy had an extended case of this ailment while the team was tweaking the software to eliminate belt stripping. Eventually Will and Tyler hit upon the right combination of settings to eliminate cogging in that particular setup. I'm guessing that's exactly what you are going to have to do--play with the settings in Castlelink. I thought I heard there was a forum member who worked for Castle. . . OTOH, shutdown when driving has always been an issue with battery current delivery in my experience. I remember one time we had attempted to wire two deWalt motors in parallel in Woodynator (brushed, not brushless, but still) and it would shut down whenever we tried to run the weapon and drive simultaneously. We wired the motors in series and the problem went away.** (of course, one motor alone would deliver more power, so that's what we ended up doing) Bench testing your setup with higher capacity or higher current rated batteries should reveal the problem--finding a suitably sized battery might be a more difficult task.
**Which led to an interesting discussion about a setup in which the motors are automatically switched from series to parallel depending on the speed--this is something I really want to investigate further some time in the future--if this were done right it would mean rapid spin up to very high speeds. In retrospect such a setup may have been a possible solution for the multimotor spinner that was smoking motors prior to Nationals (was that Matt's robot?) ahh hindsight
Subject: Re: 1 lb drum bot! Thu Jun 25, 2009 10:21 am
Here's the deal on cogging and battery capacity...imo
As stated earlier, start with a high cpacity battery pack..same voltage, but lots of amphours, then run the drive and try the weapon.
As far as cogging goes, try loosening the belt tension and check if cogging happens in both directions or just one.
If just one and in the WRONG direction, try movng the 3 motor leads over one position....this is a hint from castle when I had a similar problem.
I'll bet that loosening belt tension fixes the cogging...It's a fine line between slippage and cogging, especially on smaller bruhless setups. been there, done that.
Stiff v belts contirbute to the problem
We are running timing belts upside down (flat surface of belt against drum and pulley.
They are much more flexible and less prone to cogging....Best are the soft ones..usually not black in color.
hope this helps
Subject: Re: 1 lb drum bot! Thu Jun 25, 2009 11:00 am
nooo!! don't tell me that!! lol this battery was the ONLY ONE that fit perfectly in my design. It's the only battery short enough to fit inside my frame and the frame is all one-piece aluminum machined by HAND guys NOT CNC... noooo!!! haha
it's a common sense RC 8C 2S 800mAH battery... http://www.robotmarketplace.com/products/0-2S800-8.html 6.4A continuous and 9.6A burst discharge. The motor supposedly has a max draw of 7A. Was it unreasonable to assume it would only draw around 7A on initial spinup? I tried using my multimeter (with a 10A capacity) but I don't think I was doing it right. You're supposed to put an ammeter in series in your current, right? so i put it across the contacts of my switch, and it read 1.8A but the bot didn't turn on...
My dad has a 2S eflite battery that's got 430 mAh and 20C (8.6A max continuous). Would that be better to try? Or is it not different enough?
Since I know next to nothing about brushless motors and stuff, I just connected the three leads, and got it to spin in the right direction, then soldered them. I didn't know anything about cogging lol. My drum only has one direction of spin (it's a thunderbird 18). I agree that my belt tension may be too much... I'll slot the holes for my motor mount. I'm running timing belts too, but I've actually got mine teeth down in the pulleys cause I thought the backs of them might be TOO slippery... They're extremely flexible but are black and don't stretch cause they've got kevlar cords in them...
Then I was spinning the drum, and I was just letting it sit at 3/4 throttle ish and after like 20 seconds, it just stops. The radio light went out and it started beeping cause it was searching for the radio signal.
So sometimes, the radio disconnects and I have nothing, then other times, it'll disconnect, then reconnect pretty quickly and I have drive but no weapon... :/ hmms
Here's a video I took of my problems. (that sounds really funny lol)
And I never made it to full throttle...
Subject: Re: 1 lb drum bot! Thu Jun 25, 2009 11:43 am
The radio is disconnecting because battery voltage is dropping out.
Try a test with a separate battery for the receiver....a small 6 volt camera battery works
startup amperage on the motor could be a lot higher than you think
You might be in trouble with the burst rate of that battery pack
I've modified lipo packs, you could get a 20 or 30c pack and separate the cells into different locations in the bot to make things fit
Until you know the max amp draw, you're shooting blind.
A smal suggestion as well....dump the connectors and use micro deans
The Castle Controllers have Voltage cut-off for LiPo Batteries! Also, Some have Amperage Limits!! You're tripping at least one of those!!!!! GO IN AND PROGRAM THE CONTROLLER! that should fix it!
I think...
I think...
actually, receivers don't like more than .1 or so voltage fluctuation, so that is more likely the problem.
We had this problem when running higher voltages, where the bec on the esc was de-rated to like 25ma....baaaah
but isn't the receiver supposed to work from like 4.5 to 6 volts? I can't imagine a battery charged to 7.4+ volts would drop below four to spin up the drum, but I could be wrong...
In order to program the thunderbird, I need to buy something, right? Castle link?
I'm not too worried about the cogging, so I'll leave that be for now... there are bigger problems to solve!
with a fully charged battery there seems to be much less of a problem... but the drum isn't quite perfectly balanced, so the whole bot vibrates... let me tell you a story.
I put the throttle up to about half. I put the controller down on my stool and knelt to look at my bot vibrating in a little circle on the floor. I stand up and knock the controller off my stool, which pushes the throttle (of course) all the way up. Immediately the motor screams and the whine of everything spinning gets much much more high pitched and urgent sounding. As I'm reaching frantically for the controller to turn it off, I hear a frrrrrpptt as something gets chewed. When I finally get everything stationary, the receiver chip vibrated its way into the path of my drum teeth, and I ripped off part of the side panel and one of the antennae. It still works sans antenna and the light is brighter now, but it really scared me lol. To be not in control of something spinning that fast (est. 8K rpm?) is frightening. Especially in my bedroom...
I'm gonna wait til tomorrow when I hot glue everything in place to do more testing so I don't do any more damage lol.
You need a lasso and I hope you have safety glasses and full body armor in your bedroom
It's voltage FLUCTUATION that can cause the receiver to fall out.
But with the light shining brighter and no antenna, maybe you fixed it ???
I'm glad you didn't get hurt...so I have to laugh....it's a funny story
The 1 pound out of control bott in the bedroom trick...hahaha
What's next?
btw: charging the battey helps, no?
I believe that voltage cutoff is disabled by default, but if the tbird can be used with castle link, you could tweak the throttle curve and get a bit more startup juice. minor in light of the current situation
yeah there's more than enough power in the motor to go right up to half throttle+ with almost no hesitation, so I'm not too worried about it...
haha yeah it definitely freaked me out lol. I'm putting testing on hold til i secure things and put safety glasses on in my garage
Subject: Re: 1 lb drum bot! Fri Jun 26, 2009 1:23 am
Subject: Re: 1 lb drum bot! Fri Jun 26, 2009 1:44 am
I would have loved to see a video of the event
THE WITTLE BOT BOUNCING AROUND ON THE FLOOR, SHREDDING IT'S OWN GUTS WHILE YOU'RE CHASING AFTER THE TRANSMITTER
Definitely a Kodak moment
Subject: Re: 1 lb drum bot! Fri Jun 26, 2009 9:20 am
Careful, K? It may be small, but 4S liPo at 6amps current draw can deliver around 50 watts, and the spinning drum accumulates energy up to full speed. You could definitely lose a finger (or toe, if you're barefoot), and the safety glasses are pretty much a necessity.
Of course, this sage advice is coming from the guy who thought it would be OK to have a 10 bot rumble in a parking garage, and ended up with a postage stamp sized gash in one student's face.
My point is, we all can be stupid sometimes--at least in your case no one was hurt!
It seems you have eliminated the cogging issues, but if you want to program the Tbird: Here's the CastleLink USB programming kit It's a worthwhile thing to have and to understand, especially since Brushless is definitely here to stay.
Lastly, about the belt tension--I have preached to my team til I'm blue in the face that one MUST do the calculations if one wants to use belts, but it seems no one wants to hear it. SDP/SI (Stock Drive Products) has a great online utility that allows you to enter the pulley and belt sizes, and it tells you exactly what center distance you need. Center Distance Calc Of course, if you later decide to change your pulleys/ratio, then things need to be adjustable.
Subject: Re: 1 lb drum bot! Fri Jun 26, 2009 9:56 am
Good stuff Bob
Dan...I wthink you should add a tech section to the forum...I have plenty to add to Bob's post and it could be a good thing to have the technical mumbo jumbo all in one place
Subject: Re: 1 lb drum bot! Sat Jun 27, 2009 5:24 am
CONGRATULATIONS!!!
A battlebot isn't a battlebot, until it has in some way either injured or almost injured its creator. Let us welcome Conundrum with open arms. YEA CONUNDRUM!
As far as your radio issues go, I think I might have had the same problem with Tornado Mini. My radio was also cutting out for no reason and eventually (at the competition) the light got really bright and then wouldn't connect at all. ( I hate electrical issues right before a match)
A couple things to try:
Check if your controller was recalled. I know you're using a Dx5, and it was the 6 model that had the recall, but that might be something to look into. I actually sent mine in and got their seal of approval, just a couple days before competition.
Second, my receiver was doing the same thing and eventually just died. Even though my trims were set and everything was bound properly, I still had motor creeps, despite the reprogramming of the esc's. I'm sure you've done this already, but try using a different receiver. Why are you using an AR model receiver anyway?
Btw: What the hell kind of a dumb @$$ are you that you would let that kind of a freak accident happen!? WHAT THE HELL DAN! Seriously.
